Make MKV not accepting new BETA key
Hubird
Post by Hubird »
I have used MakeMKV a few times (upgraded BETA versions a few times) now it seems to have gotten itself in a bit of a tizzy.
It does not seem to be recognising the current BETA code with the current version, is there some way of doing a COMPLETE fresh reinstall of it?
Re: Make MKV not accepting new BETA key
Which version do you have installed? 1.9.0's key should be good for at least another month.
In any case, if Mike is late in getting the key updated, sometimes you need to set your system DATE back to before the old key expired, start MakeMKV, then apply the new beta key. Once MakeMKV is started, the date can be restored.
mcnugget
Post by mcnugget »
this just happened to me too. I had it happen once before over a year ago, I wound up waiting till the next build and it rectified itself. this time I've double checked the system time (it's correct), and I'm using the key that says it expires march 2015... no idea, but it keeps spitting it back at me.
ggking7
Post by ggking7 »
Same thing here. I'm on 1.9.1 and the latest March 2015 key doesn't work.
jesgar130@gmail.com
Post by jesgar130@gmail.com »
Same here. Activation code not working.
OutermostJeff
Post by OutermostJeff »
same
onthebeach
Post by onthebeach »
I was experiencing the same issue today. I remembered I had previously updated to 1.9.1 in January.
The workaround I successfully used:
1. I grabbed the previous version 1.9.0 from: /download/old/
2. Uninstalled 1.9.1
3. Installed 1.9.0
4. Registered the new key
5. Confirmed the package was working
6. Installed 1.9.1 again
7. Confirmed software id working as normal.
deewan
Post by deewan »
I'm having the same issue. I will try installing the old version but I was informed by the software I needed to install the newest version. Hopefully this is just a temp thing.
ggking7
Post by ggking7 »
That worked, but I noticed the key changed since yesterday so it probably works in 1.9.1 anyway now.
deewan
Post by deewan »
ggking7 wrote:That worked, but I noticed the key changed since yesterday so it probably works in 1.9.1 anyway now.
Yes, I saw the same. It does work for 1.9.1 for me.
