Gone Girl - No FUTs
quark
Gone Girl - No FUTs
Post by quark » Sun Jan 18, 2015 3:11 am
I have latest 1.9.0 and web download of SVQ turned on, but still get no FUTs and blocky video. Sent dump file in email.
Loaded 72 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /home/michael/.MakeMKV/dump_Gone_Girl_BBE3F5FF5574046E.tgz
Re: Gone Girl - No FUTs
Post by Woodstock » Sun Jan 18, 2015 3:48 pm
Since you've sent the file to Mike, try the rip again in a couple of days. Once Mike generates an SVQ file, it will simply start working.
If he needs additional information, he'll contact you.
johnmacklin
Post by johnmacklin » Sun Jan 18, 2015 7:23 pm
I sent the relevant files to Mike last week. Within a few hours, he'd updated the SVQs and I was able to rip the BD.
Has the OP got automatic updates on?
nickbuol
Post by nickbuol » Tue Jan 20, 2015 8:05 pm
I ran into the same problem and for some reason the makemkv.com site was down yesterday when I was trying to do it. I fired up AnyDVD (normally a no-no) and used MakeMKV to rip it. Worked fine without all of the blockiness.
Just a thought for situations like this. You should be able to get a free trial of AnyDVD if need be if you ever have a situation like that. I've only had to use AnyDVD 3 times for things like this, and that was just because I was too impatient to either wait for the updates, or like this time the site was down and I just took matters into my own hands. Otherwise MakeMKV has a great track record. Thanks for uploading the logs so that it can be resolved for others.
mbmapit
Post by mbmapit » Sun Feb 01, 2015 2:45 pm
I'm having the same issue and can't seem to find a solution :(
Post by Woodstock » Sun Feb 01, 2015 5:25 pm
If you have automatic updates enabled in your configuration ("Allow contacting web server for updates" is checked on the General tab of preferences), AND your firewall doesn't prevent the contact, any new SVQ files will be downloaded automatically.
If you want to make sure he has the best information possible, send the TGZ file mentioned in your logs to svq@makemkv.com when you get a chance.
mbmapit
Post by mbmapit » Mon Feb 02, 2015 6:14 pm
Woodstock wrote:If you have automatic updates enabled in your configuration ("Allow contacting web server for updates" is checked on the General tab of preferences), AND your firewall doesn't prevent the contact, any new SVQ files will be downloaded automatically.
Sending now thanks :)
cpitchford
Post by cpitchford » Tue Feb 03, 2015 12:25 am
I'm not sure if this is related, but I'm having problems ripping Gone Girl.
Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading 'BD-RE MATSHITA BD-MLT UJ262 1000' at offset '3448240128'
At the start of the rip, then it bombs out about 55% in (about an hour later)
This error sounds like either a bad disc or a bad drive, but it's the first time I've seen this error, and I've not had a problem ripping any of the other discs that arrived in the mail today.
Is there any chance this is a copy protection technique to screw up BR data drives, like the awful Copy-Control for audio CDs? I'm guessing it could be a defective disc, I'll try it in my PS3 later but was wondering if maybe this is something stranger.
Post by Woodstock » Tue Feb 03, 2015 3:06 pm
It is possible that the disk contains references to locations not on the disk, but not as likely as there simply being a problem with an unreadable spot, OR the drive can't reach where it needs to read.
I'd suggest making sure the drive is clean, carefully blowing any dust out of it.
How does MakeMKV show the disk when you first insert it, i.e., "single layer", "double layer", etc.?
Nuttson
Post by Nuttson » Tue Feb 03, 2015 5:25 pm
Hey there,
i have strange artefact's after ripping the film and i got a warning about some FUT´s :?:
Im using version 1.9.1 and automatic updates are enabled.
Any chance that this is "normal" with the recent version, and an update is coming soon?
If it should be already fixed then how to create a log and send it over?
Greetings!
mbmapit
Post by mbmapit » Tue Feb 03, 2015 6:47 pm
I've sent the dump file but had no response yet. I've just tried and am still getting the no FUT's error and the resulting file had very bad video errors (blocky). This is the only disc I am getting these errors with and presume it is because it is so new?
mbmapit
Post by mbmapit » Tue Feb 03, 2015 6:48 pm
Woodstock wrote:It is possible that the disk contains references to locations not on the disk, but not as likely as there simply being a problem with an unreadable spot, OR the drive can't reach where it needs to read.
Manufacturer: ATAPI
Product: iHES112 3
Revision: ML05
Serial number: 3782512043 226224501054
Firmware date:
Bus encryption flags: 12
Highest AACS version: 50
Disc Information
Label: Gone Girl
Timestamp: 2014-11-20 13:01:11
Data capacity: 46.26 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
mbmapit
Post by mbmapit » Tue Feb 03, 2015 6:49 pm
MakeMKV v1.9.1 win(x86-release) started
Evaluation version, 27 day(s) out of 30 remaining
Loaded 45 SVQ file(s)
Saved BD+ dump file as C:\Users\Mark/.MakeMKV/dump_Gone_Girl_81A7B5290E3E09E6_D.tgz
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00250.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00252.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00251.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00253.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00254.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00020.mpls was added as title #0
File 00801.mpls was added as title #1
File 00800.mpls was added as title #2
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00801.mpls and was skipped
File 00021.mpls was added as title #3
Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01756.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00151.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00152.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00153.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00154.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00155.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00156.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00158.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00159.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00160.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00197.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00162.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00163.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00164.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00165.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00166.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00167.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00168.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00169.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00170.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00171.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00172.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00176.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00179.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00180.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00182.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00183.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00185.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00186.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00187.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00189.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00190.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00188.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00191.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00192.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00193.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00194.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00195.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00196.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00150.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00727.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00233.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01757.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01763.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01764.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01765.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01766.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01767.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01768.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01769.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01770.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #01771.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Nuttson
Post by Nuttson » Tue Feb 03, 2015 8:46 pm
@mbmapit
Same results i had but is the MKV gold, without any crap in it?
mbmapit
Post by mbmapit » Tue Feb 03, 2015 8:47 pm
Nuttson wrote:@mbmapit
Gold? I only rip the main film and 1 audio track, I have however tried all different approaches with no luck :(
