Unable to load all titles for DVD
iscb2015
Post by iscb2015 »
I have a DVD with at least two titles which have the same film but two different soundtracks (one Portuguese 5.1, the other English 5.1) makemkv (version 1.9.1) is skipping one track which seems to be the one with the English 5.1 soundtrack.
I have added the *NOFILTER* to the preferences but this does not seem to have made any difference (see below for the contents of the log window). The issue seems to be that makemkv is skipping a title because it thinks it's the same (even though I have the no filter set) Any suggestions ?
Ian
MakeMKV v1.9.1 darwin(x86-release) started
Optical drive "DVD+R-DL OPTIARC DVD RW AD-5630A 1AHNd" opened in OS access mode.
LIBMKV_TRACE: Will keep all titles
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Cells 21-end were skipped due to cell commands (structure protection?)
Title #2 was added (20 cell(s), 1:41:12)
Cells 22-end were skipped due to cell commands (structure protection?)
Title #3 was added (20 cell(s), 1:41:12)
Cells 2-end were skipped due to cell commands (structure protection?)
Title #4 was added (1 cell(s), 0:04:44)
Cells 3-end were skipped due to cell commands (structure protection?)
Title 2 in VTS 2 is equal to title 1 and was skipped
Re: Unable to load all titles for DVD
You can try using the manual mode to get to the track being skipped: http://www.makemkv.com/manualdvd/
iscb2015
Post by iscb2015 »
Thanks for the info - the Manual DVD mode seems like the thing I need - however having selected each title individually I'm still not getting to the track which has the English 5.1 sound - I'm going to try out the DVD later on the DVD player and see if it works at all ..
