Beta Registration key fails to activate
cheepcherokee
#1 Post by cheepcherokee » Sat Jan 31, 2015 5:37 pm
I am a first time poster but long time user of MakeMKV so go easy on me. I love the application and refuse to use any other when it comes to Blu-ray and DVD disks.
I noticed that when I applied the beta license key today that the app continued to give me a dialog box that said: "The license key has expired and has been removed. Restart the application."
I applied the key several times, rebooted my PC and applied the key again. I manually added the key to the registry entry located at: HKEY_CURRENT_USER\Software\MakeMKV\app_Key but got the same result. I installed MakeMKV on another PC and got the same result.
The only thing that worked is setting the date back 1 year within the OS. Now the evaluation does not show expired anymore.
Has anyone else come across this recently? I do apologize if this is a re post, I did a short search and did not find anything more than suggestions to apply the beta key located at thread: http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053 which I already knew about. I have used MakeMKV for a long time now so this was not news to me :)
Re: Beta Registration key fails to activate
#2 Post by mike admin » Fri Feb 06, 2015 8:49 pm
Our mistake, the key is now updated.
Meegwell
#3 Post by Meegwell » Tue Feb 10, 2015 11:27 pm
mike admin wrote:Our mistake, the key is now updated.
I am relatively new to Makemkv but I am stuck in a loop of failed registration key messages.
I used T-fYWqZ5aJ9q89wyzdBuNeCpufU1JlFApsQi2eCoYqVhRYQEFWoacW2qjStHO8RaAGXo on beta 1.9.1 it says ok restart, then when I restart it says key expired and has been removed.
Im on the latest Yosemite fwiw.
Meegwell
Meegwell
#4 Post by Meegwell » Tue Feb 10, 2015 11:32 pm
Meegwell
I found the license key post and it appears to have changed and now I am ok.
