I used this key and re-started the program. But it keeps re-popping up each time I load it.
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Whats wrong?
I'm using the Linux version, it worked fine until now.
						Key not working.
Re: Key not working.
Same issue here.
To be sure I redownloaded latest version and installed makemkv to register with latest key (T-fYWqZ5aJ9q89wyzdBuNeCpufU1JlFApsQi2eCoYqVhRYQEFWoacW2qjStHO8RaAGXo)
I'm using OS X Yosemite 10.10.2 on my iMac, Late 1012.
EDIT:
Although DASPI extension worked forever for me... today I get this message:
MakeMKV v1.9.1 darwin(x86-release) started
Optical drive "BD-ROM PLEXTOR BD-ROM PX-B120U 1.06" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
and it does not help to reinstall it...
EDIT:
Similar issue here. Linux Fedora, MakeMkv upgraded to 1.9.1 and key from http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053 not working. Errors, Temporary key expired, and then version too old reportedEliminator wrote:I'm using the Linux version, it worked fine until now.
See also Linux forum http://www.makemkv.com/forum2/viewtopic ... 588#p37588
				RarefiedAir03
Yes, same issue here.  As a work around I changed my computer date to 1/29 just to see.  Sure enough, that worked.  You'll have to enter the key that's currently posted and restart mkv but it will work.
Frank
						Frank
				JerseyJerry
I had the same problem, so I loaded MakeMKV on another computer that didn't have it before and it's working there in 30-day trial mode.  I figure whatever the issue is will be fixed before 30 days!
Same here.  It is running as a 30 day trial.
I experienced the same issue with the new key from the forums not working.  I solved it by removing the plist file. (preferences/config file).
In Terminal type:
rm ~/Library/Preferences/com.makemkv.MakeMKV.plist
This will create a new file on the next start of MakeMKV.
						In Terminal type:
Excellent.  Thank you.  That worked for me.
