MKV provides this after not copying:
This disc uses newer version of AACS protection. ...
FURY
Re: FURY
Log needed. See FAQ in signature.
When you get a message like this, there should be a file created, and a message to send that file to support@makemkv.com . It will also show you what version of MakeMKV you are using, and whether or not there is a newer version out there. And, sometimes, it shows read errors that may be the real cause for the problem.
Version 1.9.0 was just replaced by 1.9.1 a few days ago. Main difference is 1.9.0 works up to AACSv50, and 1.9.1 works with the just-released AACSv51.
scifi451
Re: FURY
I have the latest update 1.9.1 and while it was able to decrypt Fury I still got errors when I tried to rip the file. I tried it twice to make sure.
This is the error messages it printed out:
https://www.dropbox.com/s/i6mmqjjszbqte ... y.jpg?dl=0
