MakeMKV fails after writing first 35MB
thosti
Post by thosti »
Hi! I have some strange behaviour with two movies. I created MKV from both movies (without any read error) and when I load this MKVs into MakeMKV again (f.e. to remove some unwanted subtitles) the writing stops after 33.4 MB (with Video selected only, with Audio is on 35MB). Strange because on both different movies I have the same behaviour and also the identic error:
DEBUG: Code 449 at 2.h*jcA)&P>e2qtLsBH:121267822
DEBUG: Code 0 at T.:s=\sXn]k9ipju<OKX9:213135090
DEBUG: Code 0 at )$R/+E!b05*wU+2o?:213131893
DEBUG: Code 0 at )$R/+E!b05*wU+2o?:121263406
DEBUG: Code 0 at )$R/+E!b05*wU+2o?:29393907
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Any idea?
Re: MakeMKV fails after writing first 35MB
Quick fix: You do NOT have to use MakeMKV to remove tracks from an existing MKV file. Search for "mkvtoolnix" in your favorite search engine.
As for the exact errors, Mike will have to look at your report.
Post by mike admin »
Please send the full log file (as written by MakeMKV) for each problematic MKV file, as it contains required additional information.
