Sin City 2 - UK R2 - Medium Error
Lucid
Post by Lucid » Wed Jan 28, 2015 6:05 pm
Hello folks, this is my first time posting so if I've not included the correct info then just let me know and I'll amend:
MakeMKV v1.9.1 win(x86-release) started
Title #1 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 was added (1 cell(s), 0:02:09)
Title #6 has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 was added (1 cell(s), 0:03:57)
Title #10 was added (1 cell(s), 0:03:42)
Title #11 was added (1 cell(s), 0:03:17)
Title #12 was added (1 cell(s), 0:02:07)
Title #13 was added (1 cell(s), 0:06:23)
Title #14 was added (1 cell(s), 0:05:24)
Title #15 has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 was added (1 cell(s), 0:26:38)
Title #18 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20/16 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 was added (8 cell(s), 0:08:51)
Title #22 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Title #23 was added (5 cell(s), 1:38:16)
Title #24 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 was added (5 cell(s), 1:38:16)
Title #26 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #27 was added (5 cell(s), 1:38:16)
Title #28 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 was added (5 cell(s), 1:38:16)
Title #30 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 was added (13 cell(s), 1:41:49)
Title #32 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 was added (9 cell(s), 0:21:53)
Title #34 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 was added (5 cell(s), 1:38:16)
Title #36 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #38 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #39 was added (10 cell(s), 1:06:24)
Title #40 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #41 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #42 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #44 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #46 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #47 was added (5 cell(s), 1:38:16)
Title #48 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #51 was added (12 cell(s), 1:41:25)
Title 1 in VTS 11 is equal to title 1 and was skipped
Saving 1 titles into directory D:/Video/_SIN_CITY_2_E817
Error 'Scsi error - MEDIUM ERROR:1090' occurred while reading '/VIDEO_TS/VTS_19_1.VOB' at offset '16570368'
Failed to save title 12 to file D:/Video/_SIN_CITY_2_E817/title12.mkv
0 titles saved, 1 failed
Re: Sin City 2 - UK R2 - Medium Error
Post by Woodstock » Wed Jan 28, 2015 11:18 pm
The drive can't read part of the disk. Often, cleaning the disk will fix this.
Lucid
Post by Lucid » Thu Jan 29, 2015 12:00 am
Thanks, I'll give that a go.
Is there something in the report that indicates this, or is that more of a "first go-to" solution?
Post by Woodstock » Thu Jan 29, 2015 2:51 pm
Really, any line that has "Scsi error" in it means the drive or operating system reported a problem with the disk.
Sometimes you will see messages that say something is "invalid or corrupt", and then a debug code; that's where "something weird" (not according to standard) appeared in the data, and MakeMKV is having to try special techniques to work around the problem. These are only a concern if they don't work, and the rip of that track failed.
Lucid
Post by Lucid » Thu Jan 29, 2015 8:50 pm
Thanks for that. It helps a noon greatly. Much appreciated :)
