Making MKV from ISO fails
Monty
Post by Monty »
When I try making an MKV from pre ripped ISO files, I get a failed to save title error.
Using newest MakeMKV version (but V1.4.11 didn't give this problem on the same images)
The PC is running Win7 Ultimate 32, completely fresh install (only Daemon tools, handbrake and MakeMKV installed)
This is the debug log
Debug log started at Fri Mar 12 12:44:39 2010 , written by MakeMKV v1.5.1 beta win(x86-release)
001005:0000 MakeMKV v1.5.1 beta win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\InchServer/MakeMKV_log.txt
003335:0508 It appears that you have AnyDVD enabled. MakeMKV should process discs with most sophisticated protections without help of any 3rd party decryption software. In addition MakeMKV works faster and more reliably when it decrypts data by itself. It is highly recommended to disable AnyDVD and restart the application.
Do you want to continue anyway (errors may follow) ?
003305:0000 AACS directory not present, assuming unencrypted disc
DISCID=D6941D6A543436575645C8F9B549373732D9FCE0
003025:0000 Title #00099.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00000.mpls was added as title #0
003025:0000 Title #01055.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #01056.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00010.mpls was added as title #1
003025:0000 Title #00000.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00061.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00062.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00078.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00083.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00084.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00085.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00086.m2ts was added as title #2
003307:0000 File 00087.m2ts was added as title #3
003307:0000 File 00088.m2ts was added as title #4
003307:0000 File 00089.m2ts was added as title #5
003307:0000 File 00090.m2ts was added as title #6
003025:0000 Title #00091.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00092.m2ts was added as title #7
003025:0000 Title #00093.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00094.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00095.m2ts has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00096.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00097.m2ts was added as title #8
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory C:/Users/InchServer/Desktop/MKV/Battlestar_Galactica_The_Plan
tp=ZeNpzcbGysjIzs7JycHBx8fLxcnNzcfPxCQgISEiIiSkoKOnqWi4gKCgkJCQMBCIgIAoGYhAgDgUSEhKSICwFBJLSICADBHJycvLyigwMjFtFvBgYGYCAcQeDpGYDA4jT/58p8HWNu4CgxA+Qiv7/v2NBEozc/+S3JDGr9RjcyLi4mMdcyjDhMO+xXimDw4WL3XoM7mRc7E1sO+ymI5G4AwA5fi5o
001003:0020 DEBUG: Code 0 at j(lZ3(!Jev/Oe`s* %ek:213130973
tp=ZeNqzsrJycXGxsrIyM7OycnBwcfHy8XJzc3Hz8QkICEhIiIkpKCjp6louICgoJCQkDAQiICAKBmIQIA4FEhISkiAsBQSS0iAgAwRycnLy8ooMDIxbRbwYGBmAgHEHg6RmAwOI0/+fKfB1jbuAoMQPkIr+/79jQRKM3P/ktyQxq/UY3Mi4uJjHXMow4TDvsV4pg8OFi916DO5kXOxNbDvspiORuAMA7YgvWg==
ts1=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
001003:0020 DEBUG: Code 0 at y`!L[oWqv)}-"T}[4mTo:29394413
001003:0020 DEBUG: Code 171040 at y`!L[oWqv)}-"T}[4mTo:213129639
001003:0020 DEBUG: Code 0 at Rf$aby`s^xes'>n!y.Rk<:121264993
005003:0000 Failed to save title 0 to file C:/Users/InchServer/Desktop/MKV/Battlestar_Galactica_The_Plan/title00.mkv
005004:0000 0 titles saved, 1 failed
Application exited at Fri Mar 12 12:44:53 2010
setarip_old
Re: Making MKV from ISO fails
Post by setarip_old »
Hi!
1) There is absolutely nothing to be gained by having AnyDVD running during this procedure - so try again, with that program totally disabled.
2) Try creating the .MKV DIRECTLY from your original, commercial BluRay disc, instead of from an .ISO image file
3) What software and procedures did you use to create the .ISO image file from your original, commercial BluRay disc?
4) Did you have the .ISO mounted or unmounted when trying to convert to .MKV?
Post by mike admin »
The error log shows that you have corrupted data in ISO. It might be a problem in MakeMKV itself, but it is very unlikely.
Monty
Post by Monty »
setarip_old wrote:1) There is absolutely nothing to be gained by having AnyDVD running during this procedure - so try again, with that program totally disabled.
The original iso files were made with anydvd. There hasn't been a trace of it on my system since i discovered makemkv
setarip_old wrote:2) Try creating the .MKV DIRECTLY from your original, commercial BluRay disc, instead of from an .ISO image file
Can't at the moment. Pc Drive ate a disc - waiting for replacement.
setarip_old wrote:3) What software and procedures did you use
anydvd was originally used.
Unmounted
setarip_old
@monty
In addition to the observation by "mike-admin", you might want to click on the following link to a thread at another forum:
http://forum.slysoft.com/showthread.php?t=37885
It may provide insight as to why things may not always be what they seem...
