I have downloaded and built the latest 1.9.1 of MakeMKV for Linux. When I pop in my Transformers: Age of Extinction Blu Ray, I get two Audio tracks, both labeled "DD Surround 5.1 English".
I don't see a TruHD stream with Atmos like I would expect. Am I missing something?
Dolby Atmos (Specifically Transformers) question
Re: Dolby Atmos (Specifically Transformers) question
Any non spammers have any ideas?
For what its worth, I tried the Windows version of MakeMKV and the TrueHD track showed up. Does the Linux version 1.9.1 not support TrueHD tracks?
I case you hadn't noticed, your video track has an audio track child, which quite simply isn't possible.
Since you're using Linux, I suggest you download the correct libraries and rebuild the program from scratch.
If I remember correctly, there is a special library needed to process ATMOS audio. It's not required, though.
Found it:
Found it:
On Linux, you must compile with the latest ffmpeg from snapshot in order to get Atmos support. Building MakeMKV with latest released ffmpeg will not work.
Yeah, really weird.
I followed the directions word for word for installing under Ubuntu Linux, rebuilt from scratch - same thing.
I ended up moving the blu ray drive to my windows desktop, I'll just rip from there...
thanks
thanks
Just to make sure if someone else comes across this the proper way to do this is following:
1) If applicable make sure you first remove both preconfigured makemkv-bin makemkv-oss directories if you are installing same version, in other words delete preconfigured then uncompress new directories to configure
> Step 1 is very important, if installing same version and if you omit it and follow steps below you will NOT compile with necessary libraries to see TrueHD
2) I choose to follow uninstall instructions here
> http://www.makemkv.com/forum2/viewtopic.php?f=3&t=3924
# Remove the config files
rm -fr ~/.MakeMKV
# Remove the actual program
sudo rm /usr/bin/makemkv
sudo rm /usr/bin/makemkvcon
> Not sure if 100% necessary but these are my steps
3) Follow the install guide here for Linux
> http://www.makemkv.com/forum2/viewtopic.php?f=3&t=224
> First do this part OPTIONAL: Building with latest libavcodec.
> I chose the 2nd configure option
> ./configure --prefix=/tmp/ffmpeg --enable-static --disable-shared --enable-pic --disable-yasm --enable-libfdk-aac
> If you get an error saying something like > libfdk_aac not found then do following:
sudo apt-get install libfdk-aac0 libfdk-aac1 libfdk-aac-dev
> I found I needed all three for it to work
4) Build makemkv-oss under the OPTIONAL section
5) Build makemkv-bin as normal
If configured correctly you will have to accept makemkv license agreement. You may have to reenter your registration code.
Hope this helps.
rm -fr ~/.MakeMKV
Hope this helps.
I had 2 issues with this...xbmcuser wrote: > If you get an error saying something like > libfdk_aac not found then do following:
1. libfdk-aac1 doesn't appear to exist; any help on how to download this?
2. even without libfdk-aac1, I still get the libfdk_aac not found error in red.
