Errors on Guns, Girls and Gambling Blu-ray
kamcknig
Post by kamcknig » Sun Jan 25, 2015 2:33 pm
MakeMKV is able to scan the disc but when I save the title, it will start and get about a quarter of the way through and then stops with an error. Here is the output window content
MakeMKV v1.9.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Kyle/MakeMKV_log.txt
The new version 1.9.1 is available for download at http://www.makemkv.com/download/
Title #00013.mpls has length of 118 seconds which is less than minimum title length of 900 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00020.mpls has length of 118 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00306.mpls(1) has length of 313 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00014.m2ts has length of 25 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00015.m2ts has length of 25 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00016.m2ts has length of 59 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00017.m2ts has length of 59 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00018.m2ts has length of 25 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00019.m2ts has length of 14 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00020.m2ts has length of 59 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00098.m2ts has length of 70 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00099.m2ts has length of 72 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00100.m2ts has length of 67 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00101.m2ts has length of 65 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00102.m2ts has length of 83 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00103.m2ts has length of 95 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00104.m2ts has length of 93 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00105.m2ts has length of 37 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00106.m2ts has length of 59 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00107.m2ts has length of 150 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00108.m2ts has length of 28 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00109.m2ts has length of 124 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00110.m2ts has length of 96 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00111.m2ts has length of 32 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Title #00112.m2ts has length of 32 seconds which is less than minimum title length of 900 seconds and was therefore skipped
Saving 1 titles into directory D:/Users/Kyle/Videos
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00023.m2ts' at offset '4544593920'
DEBUG: Code 0 at 6Il+lB@sBn5Nht-q66>M:121263038
DEBUG: Code 0 at IqH&<Iv30Q5zp#<9MN@%:121261888
DEBUG: Code 0 at 6Il+lB@sBn5Nht-q66>M:213130559
DEBUG: Code 2219040 at 6Il+lB@sBn5Nht-q66>M:29393286
DEBUG: Code 0 at T.:s=\sXn]k9ipju<OKX9:213135090
Failed to save title 0 to file D:/Users/Kyle/Videos/Guns,_Girls_and_Gambling_t00.mkv
0 titles saved, 1 failed
Not sure what any of this means though.
Re: Errors on Guns, Girls and Gambling Blu-ray
Post by Woodstock » Sun Jan 25, 2015 2:53 pm
It means your drive can't read the disk. It got to a point where the track wasn't where the laser assembly thought it should be, and it wasn't able to find it.
If it is just this one disk, it is probably a mastering error, and you should have it replaced. If it is all disks, it could be a drive problem.
kamcknig
Post by kamcknig » Sun Jan 25, 2015 2:56 pm
OK, thanks so much! It has so far just been the one disc. I'll ask about getting it replaced, much appreciated!
