Blu-ray fail
wessongroup
Blu-ray fail
#1 Post by wessongroup » Thu Jan 15, 2015 10:56 pm
Have tried two separated titles and not getting a save ... "fail"
Have cleaned the disks, and the laser on the player too .. no help
MakeMKV v1.9.0 darwin(x86-release) started
Optical drive "BD-RE TSSTcorp BDDVDW SN-506BB SB00d" opened in OS access mode.
Title #00099.mpls has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00001.mpls was added as title #0
Title #00102.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00216.mpls was added as title #1
Title 00218.mpls is equal to title 00001.mpls and was skipped
Title 00219.mpls is equal to title 00001.mpls and was skipped
File 00200.mpls was added as title #2
File 00201.mpls was added as title #3
File 00202.mpls was added as title #4
File 00203.mpls was added as title #5
File 00204.mpls was added as title #6
File 00205.mpls was added as title #7
File 00206.mpls was added as title #8
File 00207.mpls was added as title #9
Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00099.m2ts was added as title #10
File 00100.m2ts was added as title #11
File 00101.m2ts was added as title #12
File 00102.m2ts was added as title #13
File 00103.m2ts was added as title #14
File 00104.m2ts was added as title #15
File 00105.m2ts was added as title #16
File 00106.m2ts was added as title #17
Title #00107.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 119 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00109.m2ts was added as title #18
File 00110.m2ts was added as title #19
Title #00111.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00112.m2ts was added as title #20
Title #00114.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/wileywesson/Movies/_make MKV
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '9028239360'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '9028497408'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '9028497408'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '9028694016'
Error 'Scsi error - STATUS_05' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '9028958208'
Error 'Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED' occurred while reading '/BDMV/STREAM/00011.m2ts' at offset '9028958208'
Failed to save title 0 to file /Users/wileywesson/Movies/_make MKV/30_Days_of_Night_t00.mkv
0 titles saved, 1 failed
Can play the disk, using MacBlu-ray players ... not convert ??
Re: Blu-ray fail
#2 Post by Woodstock » Fri Jan 16, 2015 12:25 am
Same drive, same kind of error, same solution:
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=8003
