Willow - log
Damk27
Willow - log
Post by Damk27 »
Debug log started at Sat Jan 10 11:24:56 2015 , written by MakeMKV v1.9.0 win(x64-release)
001005:0000 MakeMKV v1.9.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\damk/MakeMKV_log.txt
005050:0000 Evaluation version, 6 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
DCE=nt8eaLLRibtT1xT68mEShqU6XX5DRmsSoeUqwKUcysQz4pveVZ30U0cQNhhtZqDWNBbW3Y2Hq3PGFVVJQnkMVG77jxENA8Kut2yy34MvirFRntl7qNE0ZYOlDy0An5y1UgEIIJZ10qXWIajB2Zr90MmTi4t0rxU2JA==
DCE=Bia0TyJXPI5DcycXLKCaxCk6OHq1KH3wvRCxdcr1YHC4iuPLTxw7qx0AaXahc3yyY7mQU+JGQMJtNNy7R1AgifyyPXG0UZr0yMxDFWhoJDmGTE0thbL9BUFKvSQOB0QU0vXOboD4ylKd4otHmFeg+sz84on3irhXYg==
DISCID=0A8CF549AAD4E7BFFD5BD6C8A461634F3F2877C2
003307:0000 File 00007.mpls was added as title #0
003025:0000 Title #00019.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00023.m2ts was added as title #1
003307:0000 File 00022.m2ts was added as title #2
003307:0000 File 00021.m2ts was added as title #3
003025:0000 Title #00007.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00014.m2ts was added as title #4
003307:0000 File 00013.m2ts was added as title #5
003025:0000 Title #00005.m2ts has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00016.m2ts was added as title #6
003025:0000 Title #00015.m2ts has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 233 at hMrrUGebRFvOHxDvsvk1Z+NR:0
005014:0000 Saving 1 titles into directory H:/Video/ARTHUR_2_MALTHAZARD
001003:0020 DEBUG: Code 3221225628 at B2}zA62dd&5;bCRZt /\YIC;B:121263521
001003:0020 DEBUG: Code 3221225628 at ejdslRD,FlL0!tLB:29393953
001003:0020 DEBUG: Code 2 at ht}I^~r C4mx~.[S:213137827
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4561502208'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4561895424'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4572377088'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00008.m2ts' at offset '4572905472'
001003:0020 DEBUG: Code 0 at 6Il+lB@sBn5Nht-q66>M:121263038
001003:0020 DEBUG: Code 0 at IqH&<Iv30Q5zp#<9MN@%:121261888
001003:0020 DEBUG: Code 0 at 6Il+lB@sBn5Nht-q66>M:213130559
001003:0020 DEBUG: Code 2232864 at 6Il+lB@sBn5Nht-q66>M:29393286
001003:0020 DEBUG: Code 0 at T.:s=\sXn]k9ipju<OKX9:213135090
005003:0000 Failed to save title 0 to file H:/Video/ARTHUR_2_MALTHAZARD/title00.mkv
005004:0080 0 titles saved, 1 failed
DCE=XagWw0oSYECfcANeqJ+4izN0hnmUtXP8KtQ6K9yq4zgUJdIOG8YyetkPYOWwzmxlQ62lXa9xJRrbY+RLhWiSKqKQ/cTtdviNylfYugtm5LPoAy6Y9Vm0s2pNOAJVSHrT40yr2WLScAtf2AqtkpLLCJbz+LJqiauuKA==
DCE=Z7UOy0Tvf/DecM35CDawf2JLV0mFJpwH4YHN91fmvUTG064T0541M9vFeMFx21vKLv52Kb+bepVD/ZPeGuOf/8s3NmWStVUByUI96LvADuJn0Tf0cPcyszCFg7Cot2WvAKe+yZWLeUSjSf7308yizPihOSDyo5XgJA==
DISCID=D01C1C991F425DCE9A036909A4269B1FC74D262C
003025:0000 Title #00099.mpls has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00102.mpls was added as title #0
003307:0000 File 00001.mpls was added as title #1
003025:0000 Title #00096.mpls(1) has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00050.mpls was added as title #2
003307:0000 File 00015.mpls was added as title #3
003025:0000 Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00099.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00097.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00208.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00080.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00249.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00220.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00228.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00221.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00222.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00223.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00224.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00225.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00226.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00227.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00229.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00052.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00053.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00054.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00055.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00056.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00057.m2ts was added as title #4
003025:0000 Title #00058.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00059.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00060.m2ts was added as title #5
003025:0000 Title #00061.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00062.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00063.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00064.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00066.m2ts has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00065.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00067.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00002.m2ts was added as title #6
003307:0000 File 00003.m2ts was added as title #7
003307:0000 File 00004.m2ts was added as title #8
003307:0000 File 00005.m2ts was added as title #9
003307:0000 File 00006.m2ts was added as title #10
003307:0000 File 00007.m2ts was added as title #11
003307:0000 File 00008.m2ts was added as title #12
003025:0000 Title #00009.m2ts has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00010.m2ts was added as title #13
003025:0000 Title #00011.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00012.m2ts was added as title #14
003025:0000 Title #00013.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00014.m2ts was added as title #15
005014:0000 Saving 1 titles into directory H:/Video/Elysium
004001:0000 Forced subtitles track #10 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #12 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #14 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #18 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #22 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
DCE=h9yCS1WzyhW8RMcKJaaQU+plWHoE8WurMgLIClirJnCo4zSN2CXJjx9xaxELVg1oQYqazHyI2FE2EkanvGYGE+yP5IMt7nKnd1dua977ddfoEI5Svsp3bTKgbIbpjHilzNEXIvO4pzbMvHfmYNsrRv5nVT9x2xoCtQ==
DCE=r4RSOWI8NAjUoPwn7QkkXPVXk60VfGInEbRbvB2FXLE9i2JUh+772pnvxZuXNOqaKgVvbryzOvZ1tbMpsIYK+13EJ5fj9UAAB144hnseneJWucDR25ozgnV/o3Brk+rfetyNNlSkzsMIoEm26eE8ewRDZYbQ4fHAhQ==
DISCID=D5CC06C212F6835299323D3A52764CA5364180D9
003307:0000 File 01300.mpls was added as title #0
003307:0000 File 00800.mpls was added as title #1
003307:0000 File 00302.mpls was added as title #2
003025:0000 Title #00000.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00070.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00071.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00072.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00074.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00060.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00061.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00062.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00064.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00050.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00052.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00054.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00076.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00075.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00055.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00056.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00057.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00058.mpls has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00077.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00078.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00065.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00066.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00067.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00068.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00303.mpls was added as title #3
003025:0000 Title #00019.mpls has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00300.mpls is equal to title 01300.mpls and was skipped
003025:0000 Title #00011.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00075.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00076.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00527.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00505.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00506.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00507.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00508.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00509.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00510.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00511.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00872.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00873.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00874.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00875.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00083.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00876.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00877.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00878.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00879.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00880.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00881.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00882.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00883.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00884.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00885.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00892.m2ts was added as title #4
003307:0000 File 00894.m2ts was added as title #5
003307:0000 File 00895.m2ts was added as title #6
003307:0000 File 00896.m2ts was added as title #7
003025:0000 Title #00898.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00899.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00901.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00902.m2ts has length of 44 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00903.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00905.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00906.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00907.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00908.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory H:/Video/The_Lone_Ranger
004001:0000 Forced subtitles track #6 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #8 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #16 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #20 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #24 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #26 turned out to be empty and was removed from output file
DCE=4SGYmQlgE/DqvUcHNJ1HBrrrqqJwNRR4WxZWYQMkMcvTsavXFhyargvQtpqC+n5fPLd64RmwknzuUE4hOGQYxNysAq59W9MK5/lac9g+5drAScGvCqXLdFVf2u4UDxVVX/uZrBPq2aJPp4YRPRRmB+I6zpCfOsgyAQ==
DCE=kIjkbJCvRao2qOekcCsFkCOennrHR5Wxmm1jxy5cyCRB2p8d09IkcDRwkiZir7jOMDwnaHdRUez7lFN1OAH3vXfep5Kz+V4CmsZOrIJsxCUdJZnszOpXomqX5tk+FIHIeh31VyhiYEsMFHpVxCCctcWjFvG679YP/Q==
DISCID=489B090B6D3278E9DFCE20DC3AC83D6D128A397C
003307:0000 File 00005.mpls was added as title #0
003307:0000 File 00003.mpls was added as title #1
003025:0000 Title #00001.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00007.m2ts was added as title #2
003025:0000 Title #00006.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00005.m2ts was added as title #3
003025:0000 Title #00004.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00003.m2ts was added as title #4
003025:0000 Title #00002.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory H:/Video/OLSENBANDEN_6
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
DCE=IULlpW3BIHNJ36+cvBraNAJumJxqItyQosvxXbOb0xqXDEkacgdSpomkcbdhMU40tcXVHj+kjEYKwkoQknl/7utgDuad7SfsO4fjlyVrRvvMno9HG0POQWX2ddEFHaklh2oqK7jOe9PVfPyRzr3fe3Xo+57d4d56kA==
DCE=fUJBZ2fgHIQHNDyuUNdRGDiUkgWor5lifjfA5rkOwtLLXYMw1EAcx4/pcohPE77h8KBEg5EasUR5uQoWCofFtuPiHePW8VyZ2vlqpGekwvzIZ3RZySTiSr9YYOhYUI5UBFXXqDmo7vgL+TODZwUN34vB/47CSlRWRQ==
DISCID=A4CEE84F3BA1EE33D4029B49C04C3782AE26C30B
003307:0000 File 00022.mpls was added as title #0
003307:0000 File 00015.mpls was added as title #1
003025:0000 Title #00032.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00028.m2ts was added as title #2
003025:0000 Title #00030.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00023.m2ts was added as title #3
003025:0000 Title #00022.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 76 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00029.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.m2ts has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00027.m2ts was added as title #4
005014:0000 Saving 1 titles into directory H:/Video/REJSEN_TIL_SATURN
004001:0000 Forced subtitles track #4 turned out to be empty and was removed from output file
DCE=M2+rY6FlESHJDKxIUfsqPTvemcdXlhclgySKvxdT68B0LKdrGHQrwXhvh7YfxTXlWeiGiYXzRyX5JoGIBAEYZWiEKccDRKhOAhiJJUeLE0oRnH6nG9OVorWkDskWxHdsSM/7LMc9mIzPU1Wtqa0QP+UmAeQ1XWvfdw==
DCE=LVkRTaArcoJWSxzjBsEi7QlvEgXK93nSaCxzy6rViE+APTEd6vQ5scHs2Askwe5ZazfdbnVfrQw2fN8GcX0ccqavxFew5EDu5RapJkh2kpezFDzhalulWcTIuo5I5o5RMfJonHy9gpvMaj9mqLTr1hI24B+23NrBCQ==
DISCID=17A6D5DB76CED01D73F5F09CF7CAA5F441E19005
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00002.mpls was added as title #1
003307:0000 File 00003.mpls was added as title #2
003025:0000 Title #00002.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory H:/Video/SAFE_HAVEN
004001:0000 Forced subtitles track #5 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #7 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #9 turned out to be empty and was removed from output file
DCE=GwXF2fciofpiEDi23LxdjMG8rhNCiLriyztLYG+Xj5ov1CEht3w9YxsWZGmTZWfZsHT0XEhwUw64QJSBjCI8faYtgFCyULRi4vGT3VARxuVRibfQG+TdYZ1vZnnjYZmmRg1TV7Oeeuz3+4J8cjQ1eGd2IFzaY5YE3Q==
DCE=S3gLRidgzJYxkdDGq1D0/fHaGTd9FwsuaFebfISZZJKGhZrZkTfohGXhE4DjrdGd3fNybh819fb3IGyspk1HI9NMvMs/EZCiynuzCKAKY5aATKUhE1Mxha5BSbl1z/bskw6NCKkGNf0tIK+cmyAdDIXIwB7+rLkbcQ==
003338:0000 Downloading latest SVQ(s) to D:\ ...
003317:0000 Loaded 42 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
SVQ: generic005 builtin/00000.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=B5EAA3FA526E2DB47A054CE421C04A180117848F
003025:0000 Title #00720.mpls has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00501.mpls was added as title #0
003307:0000 File 00502.mpls was added as title #1
003307:0000 File 00503.mpls was added as title #2
003307:0000 File 00500.mpls was added as title #3
003025:0000 Title #00020.mpls has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00800.mpls is equal to title 00500.mpls and was skipped
003309:0000 Title 00850.mpls is equal to title 00500.mpls and was skipped
003309:0000 Title 00302.mpls is equal to title 00502.mpls and was skipped
003309:0000 Title 00303.mpls is equal to title 00503.mpls and was skipped
003309:0000 Title 00312.mpls is equal to title 00502.mpls and was skipped
003309:0000 Title 00313.mpls is equal to title 00503.mpls and was skipped
003309:0000 Title 00801.mpls is equal to title 00500.mpls and was skipped
003309:0000 Title 00851.mpls is equal to title 00500.mpls and was skipped
003025:0000 Title #00011.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00501.m2ts is equal to title 00501.mpls and was skipped
003307:0000 File 00504.m2ts was added as title #4
003025:0000 Title #00505.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00506.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory H:/Video/Willow
002003:0000 Error 'Scsi error - HARDWARE ERROR:441E' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '8846831616'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '8846831616'
001003:0020 DEBUG: Code 4319742 at 6Il+lB@sBn5Nht-q66>M:29393286
005003:0000 Failed to save title 3 to file H:/Video/Willow/Willow_t03.mkv
Application exited at Sat Jan 10 17:17:03 2015
Re: Willow - log
The uncorrectable media errors are doing you in on this disk - if the drive cannot read the data, MakeMKV can't save it.
First step is cleaning the disk.
Damk27
Re: Willow - log
Post by Damk27 »
Are my Bluray drive in my computer really that much worse than the one connected to my TV?
I have a few error reports like this, - and even I have one disk that is not recognised by the drive at all (not just by MakeMKV but by the computer/the OS/the drive (I am not sure exactly who is responsible, but I know it's before MakeMKV is even started).
On my bluray connected to the TV it works.
Re: Willow - log
Your stand-alone bluray player is PROGRAMMED to IGNORE occasional errors, while the one that is attached to your computer is attempting to read without errors.
