Blu Ray Drive Issue/Makemkv
XboxPS4
Post by XboxPS4 »
hi
switched my desktop to a new one and swapped the dvd for my old pioneer blu ray writer
but every time I open Makemkv is keeps searching for a disc then says no disc (has there isn't a disc in the tray) and then keeps researching for a disc
can anyone help
Please
Re: Blu Ray Drive Issue/Makemkv
What happens if you put a CD in the drive and try to open it with Media Player or VLC? Same with a DVD?
XboxPS4
Post by XboxPS4 »
Woodstock wrote:What happens if you put a CD in the drive and try to open it with Media Player or VLC? Same with a DVD?
The Drive Plays the discs Correctly
XboxPS4 wrote:The Drive Plays the discs Correctly
That would suggest that a driver is in place that is blocking things when a BD is inserted. The new machine didn't happen to come with BD-capable playback software installed, did it?
