SCSI Error & AACS host certificate is revoked USBdrive
bimbi
Post by bimbi » Mon Jan 12, 2015 5:08 pm
i've bought a new USB3.0 external BDROM. And it does not work. I have the same issue like here:
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=4116
I think the problem is not makemkv, because alle my blu-rays working fine with the internal drive. I've alos tested makemkv as root. Same issue.
Have the drive an to old firmeware or.... i don't know.
Thanks for Help
Regards
bimbi
Re: SCSI Error & AACS host certificate is revoked USBdrive
Post by Woodstock » Mon Jan 12, 2015 5:48 pm
It would be helpful to see the EXACT error messages you're receiving... see the FAQ linked in my signature for how to get debugging information.
A lot of USB-powered drive issues are power related, but, if it is plugged into a USB3 port and it is a USB3 drive, it should have plenty of power available.
bimbi
Post by bimbi » Mon Jan 12, 2015 8:41 pm
thank you for the really fast reply :)
i tested the drive on my Gentoolinux and on an Ubuntu 14.04. On both machines it does not work, have same error messages. I have an activated licence. I was not able to test the drive on an windows system, because my win8 is broken (no mouse and keyboard :evil: ) I tested on USB3.0 and 2.0 with powercable and without powercable, same issue. Here are the Log:
MakeMKV v1.8.13 linux(x64-release) started
Debug logging enabled, log will be saved as /home/loma/MakeMKV_log.txt
The new version 1.9.0 is available for download at http://www.makemkv.com/download/
DEBUG: Code 0 at >KQ"Y7pH72B*BpZ!!:213130559
DEBUG: Code 0 at *L@iir#>'|/{DH3"aC:29395218
DEBUG: Code 0 at *L@iir#>'|/{DH3"aC:29394643
DEBUG: Code 1 at *L@iir#>'|/{DH3"aC:29394643
DEBUG: Code 2 at *L@iir#>'|/{DH3"aC:29394643
DEBUG: Code 3 at *L@iir#>'|/{DH3"aC:29394643
DEBUG: Code 4 at *L@iir#>'|/{DH3"aC:29394643
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..03E8F8B9C2DEA1A10841DEE669211D16368 to device 'SG:dev_11:2'
DEBUG: Code 0 at >KQ"Y7pH72B*BpZ!!:213130743
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0E33753E21B1DC68A6E08CC64C94E6C85AC to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..01126B0A6C1A5F1BACCCC8E9280F13C8E0B to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..064C5B4268D07A5F7A4715A3E4D237FD3D0 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0B14B0681FE317195A31C2FC7ACC2BEAC6A to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..03377A076577BE5360CC29697C04B4170B8 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0107E1B7194662683F186D51CFC05810057 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0650DB2DD7E958B053DD1445E74F382B2B9 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0CC415056E123E339B87083B6F4667CF671 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..01AAEE5B9AE96EF41F9F16B01BD481C8286 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..0800024C0 to device 'SG:dev_11:2'
DEBUG: Code 0 at *L@iir#>'|/{DH3"aC:121264487
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..021627D54DA2B2260A22630024183C5CFF5 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..044F964732912BCEE1733B19E2C20424D05 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..076F4A85C222DBFD2B713C3A10C650447F0 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0AF436F2D08CF31277CA7C5C1458F6389B7 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..016182F4C3E5D41C4E846C7A54A8A18FA36 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..09C2883EC537A26E3B3940D3110B4DE3786 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0EF5FC97AB7E22BC06AD4B78DB6F4CC9E9A to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0A50A52D9DD880DAF7D92F177EFDCCD70D0 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..01E61744C59AE73B6241F51AF7C2689C5D8 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0B6DA93ACF43C49823B178EE3785B2ACA72 to device 'SG:dev_11:2'
Highest AACS version is v47 , MKB saved as /home/loma/.MakeMKV/MKB_v47_I_Spit_On_Your_Grave_2.tgz
DEBUG: Code 0 at erlj.VaAS@KK69f*:213131962
DEBUG: Code 0 at erlj.VaAS@KK69f*:29397357
With same version and internal SATAdrive it works with the same bluray fine. I've bought this drive: http://www.amazon.de/gp/product/B00FRIH ... ge_o00_s00
Best Regards
bimbi
