SCSI Error & AACS host certificate is revoked USBdrive
bimbi
Post by bimbi »
i've bought a new USB3.0 external BDROM. And it does not work. I have the same issue like here:
http://www.makemkv.com/forum2/viewtopic.php?f=8&t=4116
I think the problem is not makemkv, because alle my blu-rays working fine with the internal drive. I've alos tested makemkv as root. Same issue.
Have the drive an to old firmeware or.... i don't know.
Thanks for Help
Regards
bimbi
Re: SCSI Error & AACS host certificate is revoked USBdrive
It would be helpful to see the EXACT error messages you're receiving... see the FAQ linked in my signature for how to get debugging information.
A lot of USB-powered drive issues are power related, but, if it is plugged into a USB3 port and it is a USB3 drive, it should have plenty of power available.
bimbi
Post by bimbi »
thank you for the really fast reply :)
i tested the drive on my Gentoolinux and on an Ubuntu 14.04. On both machines it does not work, have same error messages. I have an activated licence. I was not able to test the drive on an windows system, because my win8 is broken (no mouse and keyboard :evil: ) I tested on USB3.0 and 2.0 with powercable and without powercable, same issue. Here are the Log:
MakeMKV v1.8.13 linux(x64-release) started
Debug logging enabled, log will be saved as /home/loma/MakeMKV_log.txt
The new version 1.9.0 is available for download at http://www.makemkv.com/download/
DEBUG: Code 0 at >KQ"Y7pH72B*BpZ!!:213130559
DEBUG: Code 0 at *L@iir#>'|/{DH3"aC:29395218
DEBUG: Code 0 at *L@iir#>'|/{DH3"aC:29394643
DEBUG: Code 1 at *L@iir#>'|/{DH3"aC:29394643
DEBUG: Code 2 at *L@iir#>'|/{DH3"aC:29394643
DEBUG: Code 3 at *L@iir#>'|/{DH3"aC:29394643
DEBUG: Code 4 at *L@iir#>'|/{DH3"aC:29394643
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..03E8F8B9C2DEA1A10841DEE669211D16368 to device 'SG:dev_11:2'
DEBUG: Code 0 at >KQ"Y7pH72B*BpZ!!:213130743
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0E33753E21B1DC68A6E08CC64C94E6C85AC to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..01126B0A6C1A5F1BACCCC8E9280F13C8E0B to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..064C5B4268D07A5F7A4715A3E4D237FD3D0 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0B14B0681FE317195A31C2FC7ACC2BEAC6A to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..03377A076577BE5360CC29697C04B4170B8 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0107E1B7194662683F186D51CFC05810057 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0650DB2DD7E958B053DD1445E74F382B2B9 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0CC415056E123E339B87083B6F4667CF671 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..01AAEE5B9AE96EF41F9F16B01BD481C8286 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..0800024C0 to device 'SG:dev_11:2'
DEBUG: Code 0 at *L@iir#>'|/{DH3"aC:121264487
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..021627D54DA2B2260A22630024183C5CFF5 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..044F964732912BCEE1733B19E2C20424D05 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..076F4A85C222DBFD2B713C3A10C650447F0 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0AF436F2D08CF31277CA7C5C1458F6389B7 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..016182F4C3E5D41C4E846C7A54A8A18FA36 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..09C2883EC537A26E3B3940D3110B4DE3786 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0EF5FC97AB7E22BC06AD4B78DB6F4CC9E9A to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0A50A52D9DD880DAF7D92F177EFDCCD70D0 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..01E61744C59AE73B6241F51AF7C2689C5D8 to device 'SG:dev_11:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..0020074C100720..0B6DA93ACF43C49823B178EE3785B2ACA72 to device 'SG:dev_11:2'
Highest AACS version is v47 , MKB saved as /home/loma/.MakeMKV/MKB_v47_I_Spit_On_Your_Grave_2.tgz
DEBUG: Code 0 at erlj.VaAS@KK69f*:213131962
DEBUG: Code 0 at erlj.VaAS@KK69f*:29397357
With same version and internal SATAdrive it works with the same bluray fine. I've bought this drive: http://www.amazon.de/gp/product/B00FRIH ... ge_o00_s00
Best Regards
bimbi
