I tried with some bd (wall-e and underworld) but both vlc and xbmc are not able to play both discs. bd_info works well with both.
in /tmp i do not find ant makemkv eventlog.
bdinfo
shm@linux-p5hq:~/xbmc> MMBD_TRACE=1 bd_info /dev/sr0
MMBD: MakeMKV v1.8.7 linux(x64-release) inizializzato
MMBD: File registro evenmti abilitato. Il file registro sar? salvato in /tmp/MakeMKV-0x6f90-1.tmp
MMBD: Uso modalit? di accesso diretto
MMBD: Versione di valutazione, 27 giorni di 30 restanti
MMBD: Operazione completata correttamente
BluRay detected     : yes
First Play supported: yes
Top menu supported  : yes
HDMV titles         : 16
BD-J titles         : 3
UNSUPPORTED titles  : 3
AACS detected       : yes
libaacs detected    : yes
Disc ID             : 5DC9C6A63AE052E4D62DED9E566E78186FD71D68
AACS MKB version    : 10
AACS handled        : yes
BD+ detected        : no
Disc library metadata:
Metadata file       : bdmt_eng.xml
Language            : eng
Disc name           : Wall•E Disc 1
Alternative         : <undefined>
Disc #              : 1/1
TOC count           : 1
	Title 1: Wall•E Disc 1
Thumbnail count     : 2
shm@linux-p5hq:~/xbmc> MMBD_TRACE=1 vlc bluray:///dev/sr0
VLC media player 2.1.2 Rincewind (revision 2.1.2-0-ga4c4876)
[0x1c9c5f8] main interface error: no suitable interface module
[0x1b4c0b8] main libvlc error: interface "globalhotkeys,none" initialization failed
[0x1b4c0b8] main libvlc: Esecuzione di vlc con l'interfaccia predefinita. Usa 'cvlc' per utilizzare vlc senza interfaccia.
MMBD: File registro evenmti abilitato. Il file registro sar? salvato in /tmp/MakeMKV-0x7b78-1.tmp
[0x7f2d8c000f18] libbluray demux: First play: 1, Top menu: 1
HDMV Titles: 16, BD-J Titles: 3, Other: 3
libdvbpsi error (PSI decoder): TS discontinuity (received 7, expected 0) for PID 20
libdvbpsi error (PSI decoder): TS discontinuity (received 2, expected 0) for PID 0
libdvbpsi error (PSI decoder): TS discontinuity (received 3, expected 8) for PID 20
libdvbpsi error (PSI decoder): TS discontinuity (received 11, expected 0) for PID 18
libdvbpsi error (PSI decoder): TS discontinuity (received 9, expected 3) for PID 0
libdvbpsi error (PSI decoder): TS discontinuity (received 1, expected 4) for PID 20
shm@linux-p5hq:~/xbmc> MMBD_TRACE=1 ./xbmc.bin
libpng warning: iCCP: known incorrect sRGB profile
MMBD: File registro evenmti abilitato. Il file registro sar? salvato in /tmp/MakeMKV-0x7c1-1.tmp
MMBD: File registro evenmti abilitato. Il file registro sar? salvato in /tmp/MakeMKV-0x7d3-1.tmp
MMBD: File registro evenmti abilitato. Il file registro sar? salvato in /tmp/MakeMKV-0x7e3-1.tmp
Failed to open /run/media/shm/QUACK_D1_DEU/BDMV/PLAYLIST/-0001.mpls
Failed to open /run/media/shm/QUACK_D1_DEU/BDMV/BACKUP/PLAYLIST/-0001.mpls
MMBD: File registro evenmti abilitato. Il file registro sar? salvato in /tmp/MakeMKV-0x806-1.tmp
MMBD: File registro evenmti abilitato. Il file registro sar? salvato in /tmp/MakeMKV-0x816-1.tmp
MMBD: File registro evenmti abilitato. Il file registro sar? salvato in /tmp/MakeMKV-0x825-1.tmp
http://pastebin.com/Gsdzi9A2
