LPCM Codec ID issue
spl147
LPCM Codec ID issue
Post by spl147 »
i noticed that none of my MKV's with LPCM tracks play audio on my mac or on my mede8er. after some digging aroung i found that the codec id in the MKV was "A_MS/ACM" i changed it to "A_PCM/INT/LIT" and now i have audio.
is this something that mike can fix?
info was taken from here:http://www.mede8erforum.com/index.php?topic=10809.0
Re: LPCM Codec ID issue
Post by mike admin »
Just use FLAC profile.
crussader
Post by crussader »
How is the FLAC profile selected?
Go to Preferences, General, and check "expert mode".
Once that is checked, you can select the profile to use on the main screen before you start the extract, and you can also change which profile is the default (that's in Preferences -> Advanced, which will appear after Expert mode is turned on).
crussader
Post by crussader »
