Working Girl (BD+ code processed but no FUTs were obtained)
DJRumpy
#1 Post by DJRumpy » Thu Jan 08, 2015 4:28 pm
BD+ code processed but no FUTs were obtained, errors may follow
Re: Working Girl (BD+ code processed but no FUTs were obtain
#2 Post by Woodstock » Fri Jan 09, 2015 12:44 am
And did you click on the link that was in the status window, to report the BD+ information to Mike, so that he can create a work-around?
DJRumpy
#3 Post by DJRumpy » Fri Jan 09, 2015 1:01 am
There was no link in the status window. The error was via popup window, and not in the status window: I can upload the archive if needed, although if I recall they are fairly large.
"MakeMKV v1.9.0 darwin(x86-release) started
Optical drive "BD-ROM Optiarc BD ROM BC-5500S 1.75d" opened in OS access mode.
Loaded 31 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /Users/Username/Library/MakeMKV/dump_Working_Girl_668E77C22B9F1563.tgz
Title #00131.mpls has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00252.mpls has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00254.mpls has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00255.mpls has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00012.mpls has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00020.mpls has length of 64 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
Title 00850.mpls is equal to title 00800.mpls and was skipped
Title 00851.mpls is equal to title 00801.mpls and was skipped
Title #00310.mpls has length of 204 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00311.mpls has length of 96 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00600.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00601.m2ts has length of 0 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00131.m2ts has length of 8 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00123.m2ts has length of 20 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #01905.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00151.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00152.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00153.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00154.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00155.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00156.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00158.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00159.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00160.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00197.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00162.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00163.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00164.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00165.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00166.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00167.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00168.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00169.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00170.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00171.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00172.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00173.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00175.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00176.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00179.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00180.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00182.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00183.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00185.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00186.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00187.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00189.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00190.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00188.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00191.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00192.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00193.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00194.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00195.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00196.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00150.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00727.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00233.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00200.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00952.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00956.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00959.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #02087.m2ts has length of 87 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #02088.m2ts has length of 117 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #02089.m2ts has length of 31 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #02090.m2ts has length of 32 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #02091.m2ts has length of 32 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00953.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00955.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #01961.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #00951.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #02092.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #02093.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #02094.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #02095.m2ts has length of 10 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #02096.m2ts has length of 5 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Title #01741.m2ts has length of 32 seconds which is less than minimum title length of 1200 seconds and was therefore skipped
Operation successfully completed"
DJRumpy
#4 Post by DJRumpy » Fri Jan 09, 2015 1:12 am
Looks like the dump file is quite a bit smaller now. I'll try to attach it to this post. manually.
DJRumpy
#5 Post by DJRumpy » Fri Jan 09, 2015 1:23 am
Still can't get the attach to work in this forum. Here's a link to dropbox.
https://www.dropbox.com/s/8kj856a0gc7j2 ... 3.tgz?dl=0
#6 Post by Woodstock » Fri Jan 09, 2015 3:50 am
Fastest way is to send the BD dump tgz file to svq@makemkv.com with a link back to this message, so that Mike has context.
DJRumpy
#7 Post by DJRumpy » Fri Jan 09, 2015 2:51 pm
Done and sending it now. It was about 3 MB in size. Me.com and gmail both apparently have issues with the attachment type and/or size. I sent it from another address instead.
#8 Post by Woodstock » Fri Jan 09, 2015 5:37 pm
Ah, the joys of being your own web/mail host... not having to deal with other people's restrictions! :)
