1.5.1 for Linux
1.5.1 for Linux
Where is it
- Contact:
Re: 1.5.1 for Linux
Updated.
						Re: 1.5.1 for Linux
+1 on a failed download. Only I stupidly decided to go ahead and try it with just the binary package to see if the older version's front end would still call the new binary back end. No luck, so now nothing works and I don't have a copy of the previous download to revert to. One of these days I'll learn to archive everything, even if I don't expect to ever need it again.
Edit: I think I got it working. For anyone else having trouble until they upload the new version and fix the link, you can simply download the 1.5.0 version. (Take the currently broken link and just change it to a 1.5.0 instead.) Then replace 4 lines in makemkvgui/src/win_rsrc.rc with 1.5.1 instead of 1.5.0. And then one final change in makemkvgui/inc/ver_num.h with the same change. Everything then compiled correctly and ran with the new binary.
Re: 1.5.1 for Linux
The OSS link is still broken. I'm feeling a bit like the poor cousin.
Re: 1.5.1 for Linux
Is there any chance the link for http://www.makemkv.com/download/makemkv ... oss.tar.gz could be fixed?
Version 1.4.8 timed out and I can't build this one, thanks.
