Rip fails on 3rd disc of Basilisk anime box set (DVD)
Nazgvl
#1 Post by Nazgvl » Tue Jan 06, 2015 1:45 am
Trying to rip the third disc of the Basilisk anime economy box set (viridian edition DVD) was giving me a failure without any error shown. Poked around the forums here and saw to turn on debug logging for more insight, and this is what I was getting..
Debug log started at Tue Jan 06 01:27:52 2015 , written by MakeMKV v1.9.0 win(x64-release)
001005:0000 MakeMKV v1.9.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Daedalus/MakeMKV_log.txt
003025:0000 Title #1 has length of 22 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003025:0000 Title #3 has length of 30 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003019:0000 Cells 44-end were skipped due to cell commands (structure protection?)
003028:0000 Title #11 was added (43 cell(s), 2:24:06)
Title skip vts=5 pgcn=1 hash=3CF025CA98044A39
003032:0000 Region setting of drive ASUS:BW-12B1ST does not match the region of currently inserted disc, trying to work around...
DEBUG: Code 0 at )'>5&f05lv$A+)M8N:213130283
DEBUG: Code 0 at )'>5&f05lv$A+)M8N:213133250
005014:0000 Saving 1 titles into directory K:/Mkv output
001003:0020 DEBUG: Code 7 at [h6%WpV^_oY?MIKc+F:29398967
001003:0020 DEBUG: Code 0 at [h6%WpV^_oY?MIKc+F:121267109
001003:0020 DEBUG: Code 0 at [h6%WpV^_oY?MIKc+F:29398921
001003:0020 DEBUG: Code 355 at [h6%WpV^_oY?MIKc+F:29398944
001003:0020 DEBUG: Code 3969933920 at [h6%WpV^_oY?MIKc+F:213135297
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
005003:0000 Failed to save title 0 to file K:/Mkv output/title00.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Tue Jan 06 01:37:22 2015
Already sent a copy of the log to support@makemkv.com. Is there anything I can do for a workaround? Hate to have to stop halfway through a series.
Re: Rip fails on 3rd disc of Basilisk anime box set (DVD)
#2 Post by Woodstock » Tue Jan 06, 2015 1:32 pm
One thing I would try is to step back a version or two on MakeMKV, because it is possible that the error is in one of the libraries used in the current version. This disk should be rippable with 1.8.7, which you can download from:
/download/old/
You can install it in a separate directory from 1.9.0, so both versions would be available.
Nazgvl
#3 Post by Nazgvl » Tue Jan 06, 2015 7:50 pm
Tried your suggestion of 1.87, still no dice. Actually fails quicker on that version (as soon as you start the rip rather than a third through). Thanks anyways though.
Creating a test dump now to send to support, see if theres a way to manually do this.
Nazgvl
#4 Post by Nazgvl » Fri Jan 09, 2015 9:57 pm
Got a response from support with a manual string to open the disc with. Worked like a charm!
Here it is in case anyone else might find it useful.
11:@1-@7;@8-@14;@15-@21;@22-@28;@29-@35;@36-@42;@43
Thanks guys! You Rock.
