Problematic HD-DVDs
TrevorS
Re: Problematic HD-DVDs
Post by TrevorS »
FYI -- MakeMKV processed "Cat People" just fine! :)
TrevorS
Post by TrevorS »
Woodstock wrote:
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/HVDVD_TS/PEVOB_1.EVO' at offset '6147459072'
That says the drive can't read the disk. MakeMKV can only ask the drive to try more times (its in the Tools->IO menu), but that rarely helps. Cleaning the disk is the first step, possibly waxing it to fill in any small scratches.
Thanks for the reply! I just performed a cleaning pass and am rerunning it. I'm super anal about my discs (DVD, HD DVD, BD) so no scratches, but there could have been a speck! I'll update this post with the result.
----------------------LATER-----------------------
Sure enough, the second pass was flawless! I'll update my above problem report! :)
TrevorS
Post by TrevorS »
Just trying to process "Casablanca" and hit the same problem causing the feature to again not be read. The disc looked perfect, but I carefully cleaned it, and the problem remains. I took the disc to my HD DVD player and it has no problem whatsoever accessing the feature (it's playing right now). I'm wondering if at least sometimes when there are read errors that they could be deliberate on the part of the manufacturer so as to prevent decryption/copying (I understand this is sometimes done on DVDs -- deliberate "bad blocks"). Since my XBOX drive generally has no difficulty reading HD DVD discs, I'm wondering if this might actually be something MakeMKV is having a navigational problem with?
Casablanca
Warner Brothers
1080p VC-1
Eng,Esp,Fra DD1.0
MakeMKV can't "read" the feature film. Everything else copied fine.
-----------------SCREEN log-----------------------
MakeMKV v1.8.11 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Trevor/MakeMKV_log.txt
DEBUG: Code 0 at ~E#&/2A<MU\I*@Rm4:29393953
Title #FBILogo.EVO has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #Interpol.EVO has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #TrailerRobinHood.EVO has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #AddScenes.EVO has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/HVDVD_TS/Feature_2.EVO' at offset '65536'
DEBUG: Code 0 at !,+mNdHPXD/q|[j%Otd+:121263038
DEBUG: Code 0 at A0dg=b"A%\r^%:drGC):121261750
DEBUG: Code 0 at !,+mNdHPXD/q|[j%Otd+:213130559
DEBUG: Code 32 at !,+mNdHPXD/q|[j%Otd+:29393286
DEBUG: Code 0 at ){&>x>,?^(N$Rt<WLL~o@:213135090
DEBUG: Code 0 at S9gT+=52i:aZ7<2(Ta:29393539
DEBUG: Code 0 at S9gT+=52i:aZ7<2(Ta:213130444
Failed to decode audio/video data for title #0 - invalid mux or internal error, title skipped.
DEBUG: Code 0 at }<KN6!J%SgB[()aj:213131525
DEBUG: Code 0 at ^t3g,!!WxY^),'O:213138770
Saving 12 titles into directory K:/Conversions/MakeMKVvideoFiles/HD DVD/Casablanca
12 titles saved
TrevorS
Post by TrevorS »
Just thought I'd mention the "Casablanca" HD DVD read problem is still there. MakeMKV 1.9.0 can read everything but the feature.
EliLuc
Post by EliLuc »
I can confirm that Casablanca rips successfully. Ripped it without problems last night.
(Used Xbox 360 HD-DVD)
EliLuc
Post by EliLuc »
Been awhile since anyone has posted, so for the sake of those that come across this feed I'll add my results. Running MakeMKV 1.9.0 and most recent AnyDVD HD.
Thus far:
Lethal Weapon
Warner Brothers
1080p vc-1
Eng DD+5.1
The main feature was not copied.
Saving 3 titles into directory D:/Video/LETHAL_WEAPON
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/HVDVD_TS/FEATURE_1.EVO' at offset '13350234112'
Failed to save title 0 to file D:/Video/LETHAL_WEAPON/Feature_Presentation_t00.mkv
2 titles saved, 1 failed
Planet Earth (Disc 3)
BBC Video
1080p VC-1
DD
Fails to copy; other 3 discs ripped successfully.
Top Gun
Paramount
DD TrueHD; DTS-ES; DD+ (Eng/Spn)
Seems the original ripping errors have returned in 1.9.0
Girlvana 3 (Adult)
Zero Tolerance
Audio - Unknown
Unable to open disc in MakeMKV or AnyDVD HD
TrevorS
Post by TrevorS »
EliLuc wrote:I can confirm that Casablanca rips successfully. Ripped it without problems last night.
I just want to confirm you actually successfully ripped the film file, not just the abundant bonus content. The feature film is the first in the extracted list (file _t00). Did you actually play the file to verify you had the right one?
I just cleaned the disc yet again and tried the latest MakeMKV (1.9.1), no change in behavior. Here is the view pane content including the errors.
MakeMKV v1.9.1 win(x64-release) started
Saving 3 titles into directory K:/Conversions/MakeMKVvideoFiles/HD DVD/Casablanca
You definitely have no errors reported and you definitely have file _t00 saved in your target directory? (HD DVD appears new and playback in an A2 player is flawless)
The SCSI read error being at the same location indicates a scratch or other imperfection that the laser can't see through. Waxing the disk MAY help, if the scratch is minor. If it doesn't, it may need to be polished smooth again.
Do you have access to a disk polisher? This is something best done with the proper tools. Some DVD rental places will recondition disks for a fee.
Failing that, I've used tooth polish to LIGHTLY buff out the surface of some disks that waxing along didn't help.
bw001
Post by bw001 »
Casablanca is Warner Bros. WB HD-DVD discs go bad over time. See thread over at AVS Forum.
I have several discs that I couldn't rip and one - HP&TSS, which I was able to rip at one point and then unable to later.
OsloBergen
Post by OsloBergen »
A Christmas Story
Warner Bros.
VC-1
DDPlus
I rip all special features as well, so the main feature was the only title on this disc I couldn't transfer.
Debug log started at Wed Jul 29 22:50:57 2015 , written by MakeMKV v1.9.5 darwin(x86-release)
001005:0000 MakeMKV v1.9.5 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/XXXXXX/MakeMKV_log_1.txt
002010:0000 Optical drive "DVD+R-DL TSSTcorp CDDVDW SH-S203N LA00d" opened in OS access mode.
001003:0020 DEBUG: Code 3758097095 at SJ#SF"1NLO?Ar,TaR:UjO^eF_:29395540
002010:0000 Optical drive "BD-ROM TOSHIBA DVD/HD  X807616 MC08" opened in OS access mode.
002015:0000 It's highly recommended to install DASPI kernel extension to improve performance.
001003:0020 DEBUG: Code 0 at o)ha+xK?sRSO5C6k2:29393953
DEBUG: Code 1073741824 at 0K<\5VaPS%JSml%2:121265315
DAFD=PAAAABAAAAAA=
001003:0020 DEBUG: Code 8 at pp\/{P56\/Dff2i(N=:29393792
DCE=2Gkje3k8aDN6MwwJtwIuh83QY82X3M6TTymfbmrxDZHv3c9PdoB0nZ3mg7OAJhNRWPc5CwSQF/8f79qXoyQ79XVSWFBwMjD7EHgXvhKkfGbgGGm/Lr+f0n4/bl4N7TxgM4FAM0LXDpUn+HaYt+OeXAlRnNpUeu+0Bg==
005014:0000 Saving 1 titles into directory /Users/XXXXXX/Movies/CHRISTMAS_STORY
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/HVDVD_TS/FEATURE_1.EVO' at offset '14116691968'
001003:0020 DEBUG: Code 0 at .QtD%vG:.%AD:?$7B(v?:121263038
001003:0020 DEBUG: Code 0 at &e&>1\CyCru5_9}Hm{h:121261750
001003:0020 DEBUG: Code 0 at .QtD%vG:.%AD:?$7B(v?:213130559
001003:0020 DEBUG: Code 6892916 at .QtD%vG:.%AD:?$7B(v?:29393286
001003:0020 DEBUG: Code 0 at #qrI[{R4/$Wd92]w[m5zF:29398967
005003:0000 Failed to save title 0 to file /Users/XXXXXX/Movies/CHRISTMAS_STORY/A_Christmas_Story_t00.mkv
005004:0080 0 titles saved, 1 failed
Unfortunately, this is a problem with the disk - your drive can't read parts of it. It's possible that cleaning and waxing it may help.
OsloBergen
Forbidden Planet
Warner Bros.
VC-1
DDPlus
The Invisible Boy
Warner Bros.
mpeg4
DDPlus
I included both of these in the same post because they are on the same disc. Same problem as my previous Christmas Story post, I can rip everything from the disc except these two titles.
Debug log started at Thu Jul 30 02:55:48 2015 , written by MakeMKV v1.9.5 darwin(x86-release)
001004:0000 Debug logging enabled, log will be saved as /Users/XXXXXX/MakeMKV_log.txt
DAFD=PAAAABAAAAAA=
DCE=WBhF/XAHDCPflNr+J7YgIT7IMMFtYxbg4msb025ZQP7t0TY/NoAMTon6A9RTGX72orQFrZMZeNRMiovaJUWLstgqqNj9s6iQaXparrpxTTndmIEkazoiSRXl0n5uUPuR/NAbuOoUPlBHHLMbaJD1ZgHCNITyOy0jZg==
005014:0000 Saving 2 titles into directory /Users/XXXXXX/Movies/FORBIDDEN_PLANET_HDDVD
004007:0010 AV synchronization issues were found in file '/Users/OsBerg/Movies/FORBIDDEN_PLANET_HDDVD/_t00.mkv' (title #1)
004008:0010 AV sync issue in stream 2,3 at 0:00:00.012 with duration of 96ms : 3 early frame(s) dropped at start
004008:0010 AV sync issue in stream 1 at 0:00:00.012 with duration of 96ms : 6 early frame(s) dropped at start
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/HVDVD_TS/PEVOB_1.EVO' at offset '216647680'
001003:0020 DEBUG: Code 105785 at .QtD%vG:.%AD:?$7B(v?:29393286
005003:0000 Failed to save title 0 to file /Users/XXXXXX/Movies/FORBIDDEN_PLANET_HDDVD/_t00.mkv
002003:0000 Error 'Posix error - Input/output error' occurred while reading '/HVDVD_TS/FORBPLTNL06LF1HD1.EVO' at offset '503060480'
001003:0020 DEBUG: Code 245635 at .QtD%vG:.%AD:?$7B(v?:29393286
001003:0020 DEBUG: Code 0 at 6uX>7<!<=yRz,xzWk+B:29396414
RH2=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
FS ID=<FAILED> C=0
TI=ZeNpjZBgYAAAA8AAC
001003:0020 DEBUG: Code 0 at /@KBsn~EzULtO~3Dd:213131893
001003:0020 DEBUG: Code 0 at /@KBsn~EzULtO~3Dd:121263406
001003:0020 DEBUG: Code 0 at /@KBsn~EzULtO~3Dd:29393907
005003:0000 Failed to save title 12 to file /Users/XXXXXX/Movies/FORBIDDEN_PLANET_HDDVD/_t12.mkv
005004:0080 0 titles saved, 2 failed
005037:0204 Copy complete. 0 titles saved, 2 failed.
OsloBergen
Woodstock wrote:Unfortunately, this is a problem with the disk - your drive can't read parts of it. It's possible that cleaning and waxing it may help.
I'm thinking it's probably the same issue, but I went ahead and posted my other problem disc, Forbidden Planet. When you say waxing, do you mean literal waxing with automotive wax? Any application tips and tricks you can share?
A bit less aggressive with waxing... :)
I use Pledge furniture polish because it is a water-based wax (not harmful to plastic surfaces), and will clean up fingerprints and other dirt. Spray on, work in using a clean finger until it starts to dry, then wipe off with a clean, soft cloth (cotton or microfiber work best), moving perpendicular to the tracks. Allow the last of the water to evaporate (takes a few seconds), then attempt the rip again.
If that doesn't get it, the next step is polishing the surface, and that's best done with the proper equipment and polishes.
GoofeyGuy
Post by GoofeyGuy »
Lucky Number Slevin
WB
MPEG4
DD+ 5.1
Debug log started at Sat Aug 08 06:05:39 2015 , written by MakeMKV v1.9.5 win(x64-release)
001005:0000 MakeMKV v1.9.5 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Hackerjac/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at /F?XkFH7QlBRA'd[):29393953
003305:0000 AACS directory not present, assuming unencrypted disc
003025:0000 Title #MAINMENU.EVO has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #MENULOOP.EVO has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #BLACK.EVO has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #WEINLOGO.EVO has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #GENLOGO.EVO has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #ALTEND.EVO has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory F:/Video/LUCKY_NUMBER_SLEVIN
001003:0020 DEBUG: Code 11113 at -hY2+&G#q}RCeAPn:213131134
001003:0020 DEBUG: Code 0 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 0 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 34560000 at -hY2+&G#q}RCeAPn:121263268
001003:0020 DEBUG: Code 5760000 at -hY2+&G#q}RCeAPn:121263291
001003:0020 DEBUG: Code 34 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 34 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 69 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 69 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 103 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 103 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 138 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 138 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 172 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 172 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 207 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 207 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 241 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 241 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 276 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 276 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 311 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 311 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 345 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 345 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 380 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 380 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 414 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 414 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 449 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 449 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 483 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 483 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 518 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 518 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 552 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 552 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 587 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 587 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 622 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 622 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 656 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 656 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 691 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 691 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 725 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 725 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 760 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 760 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 794 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 794 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 829 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 829 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 864 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 864 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 898 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 898 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 933 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 933 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 967 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 967 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1002 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1002 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1036 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1036 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1071 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1071 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1105 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1105 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1140 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1140 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1175 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1175 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1209 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1209 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1244 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1244 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1278 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1278 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1313 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1313 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1347 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1347 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1382 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1382 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1416 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1416 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1451 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1451 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1486 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1486 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1520 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1520 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1555 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1555 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1589 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1589 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1624 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1624 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1658 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1658 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1693 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1693 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1728 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1728 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1762 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1762 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1797 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1797 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1831 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1831 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1866 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1866 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1900 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1900 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1935 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1935 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 1969 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 1969 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 2004 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 2004 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 2039 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 2039 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 2073 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 2073 at -hY2+&G#q}RCeAPn:213131456
001003:0020 DEBUG: Code 2108 at -hY2+&G#q}RCeAPn:121262946
001003:0020 DEBUG: Code 2108 at -hY2+&G#q}RCeAPn:213131456
004007:0010 AV synchronization issues were found in file 'F:/Video/LUCKY_NUMBER_SLEVIN/Main_Movie_t00.mkv' (title #1)
004008:0010 AV sync issue in stream 1 at 0:00:01.984 with duration of 18.005ms : audio gap - 3.376 missing frame(s)
001001:0020 DBG ASSERT: ILm/\w=2Y3"J,,|KTj/A{#S at -hY2+&G#q}RCeAPn:213131640
001001:0020 DBG ASSERT: ILm/\w=2Y3"J,,|KTj/A{#S at <]cs7z&2\^fp<R-2l:121264073
001002:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: TimecodeDelay >= int16(0x8000) && TimecodeDelay <= int16(0x7FFF)
004047:0010 AV sync issue in stream 0 at 4744532:51:12.898 : video frame timecode differs by +632.604s
005003:0000 Failed to save title 0 to file F:/Video/LUCKY_NUMBER_SLEVIN/Main_Movie_t00.mkv
Application exited at Sat Aug 08 06:07:41 2015
