Hopw to train your dragon 2
mattmoo60
Post by mattmoo60 »
I am trying to rip a blu ray of How to Train your dragon 2 and I got the below error. I have done some searching of these forums and they suggest that the disc must be damaged? However I have tried the disc in blu ray player and it plays absolutely fine.
If anyone has any ideas I would be very grateful.
Saving 1 titles into directory G:/Video
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '559546368'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '559742976'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '559872000'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '561905664'
Error 'Scsi error - NOT READY:CANNOT READ MEDIUM - INCOMPATIBLE FORMAT' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '572387328'
Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occurred while reading '/BDMV/STREAM/00002.m2ts' at offset '572387328'
DEBUG: Code 0 at 6Il+lB@sBn5Nht-q66>M:121263038
DEBUG: Code 0 at IqH&<Iv30Q5zp#<9MN@%:121261888
DEBUG: Code 0 at 6Il+lB@sBn5Nht-q66>M:213130559
DEBUG: Code 279486 at 6Il+lB@sBn5Nht-q66>M:29393286
DEBUG: Code 0 at T.:s=\sXn]k9ipju<OKX9:213135090
Failed to save title 3 to file G:/Video/How_To_Train_Your_Dragon_2_t03.mkv
Re: Hopw to train your dragon 2
The errors say that your drive can't read the disk. In this case, the first thing I'd do is try cleaning your DRIVE, but the disk may be damaged.
"Plays absolutely fine" in a BD player means very little - BD players are programmed to skip over errors, and you'll only notice a video or audio glitch, if you're paying attention.
mattmoo60
Re: How to train your dragon 2
Post by mattmoo60 »
Thanks for the answer. I will give the drive a clean and see how it goes.
If this doesnt work I realise that suggests that the disc is damaged, is there anyway to get the software to skip over these errors and see what it produces? I dont think that I can return the disc as if it was tested on a blu ray player then it would look fine to their eyes and so I wouldnt get very far...
Cheers!
MakeMKV won't skip bad spots. I've heard of some utilities that will, but I don't have any (other than "dd" on Linux) that do that.
beat-breaker
Post by beat-breaker »
Woodstock wrote:MakeMKV won't skip bad spots. I've heard of some utilities that will, but I don't have any (other than "dd" on Linux) that do that.
Could Make MKV be updated with an option that when there's an error like this you have the option to quit or to put in some data to fill in the missing info (this could be black screen, silence or just holding a few frames of picture maybe). Make MKV knows how much data is missing or can't be read so it could fill in the gaps - if the error is small it might be preferable to buying a new disc?
Such an option kind of defeats the purpose of a program intended to give you a bit-for-bit copy of what's on the disk, doesn't it?
