JAMES BOND 50 - No FUTs Obtained error message
ggoblin31
Post by ggoblin31 »
I've tried to rip CASINO ROYALE and ON HER MAJESTY'S SECRET SERVICE, and both have popped up an error message on these discs from this boxed set. I was successful in ripping QUANTUM OF SOLACE from the set, but I fear I'm going to get this message as I try to create my James Bond library. How can I get past this error message?
Much thanks
Re: JAMES BOND 50 - No FUTs Obtained error message
When MakeMKV gives this error, it generates a link to submit the information necessary to fix the problem in the log. If you clicked on the link, Mike will generally create a new SVQ file that deals with the offending BD+ information, and MakeMKV will pick it up automatically, so long as you have automatic updates enabled.
If you didn't click on the link, I don't remember if it saves the information to a file or not.... been a LONG time since the message has happened to me. If it did create a file, it will be in the directory set under Preferences->General, as the "MakeMKV data directory". Find the file, and send it via email to svq@makemkv.com for Mike to review.
ggoblin31
Post by ggoblin31 »
Thank you
ggoblin31
Post by ggoblin31 »
Yeah, a link does not appear when this error message populates (though I know what you're referring to). I am running into a string of these: ON HER MAJESTY'S SECRET SERVICE & CASINO ROYALE (from the Bond 50 set), and now THE FRENCH CONNECTION FILMMAKERS SIGNATURE SERIES DISC. Very frustrating.
