Sin City 2: A Dame to Kill For - 180 titles
matt198t
#1 Post by matt198t » Tue Dec 16, 2014 3:01 pm
all with the same movie runtime and size.
Is there a process to find the right title?
matt198t
Re: Sin City 2: A Dame to Kill For - 180 titles
#2 Post by matt198t » Sat Dec 20, 2014 7:39 pm
The screenpass protected titles I have come across up until now have always let me narrow it down to 4-8 titles going off the movie runtime.. I then rip these titles and use chapter start/end times to work out the correct title.
This disc has 180 titles all with the same movie runtime :s
Any ideas?
VideoJunkie888
#3 Post by VideoJunkie888 » Mon Dec 22, 2014 1:25 pm
Hi matt198t...
(if you have the same version of this disc, the following should help you):
Checked and verified correct playlist as: "503.mpls"
...Correct segment order (only matched one playlist): = "00503.mpls"
Segment map : 101,179,112,103,102,104,111,114,105,110,113,106,109,108,107
The particular "track" that this "503.mpls" playlist appears as - will vary depending upon your "minimum length" preset settings within MakeMKV ~ just look at the "playlist" section in MakeMKV's information panel whilst scrolling through all the fake playlist entries until you see the correct "503.mpls".
Title information
Name: Sin City 2: A Dame to Kill For (English)
Source file name: 00503.mpls <--- * CORRECT PLAYLIST for this version of disc
Duration: 1:42:29
Chapters count: 5
Segment count: 15
Segment map: 101,179,112,103,102,104,111,114,105,110,113,106,109,108,107
File name: Sin_City_2_A_Dame_to_Kill_For_t102.mkv <--- * VARIES dep. upon MakeMKV setting
^ The above information was correct for the following UK (Retail release) Blu-ray Disc
Protection: AACS v49
Disc Information
Label: SIN_CITY_2_A_DAME_TO_KILL_FOR
Timestamp: 2014-10-15 12:31:31
Data capacity: 33.95 Gb
Disc type: BD-ROM
Number of layers: 2
Hope this helps :D
rosie
#4 Post by rosie » Mon Dec 22, 2014 4:56 pm
Thanks VideoJunkie888!
I was after exactly the same info as Matt - how did you find out what playlist it was?
Cheers!
matt198t
#5 Post by matt198t » Mon Dec 22, 2014 5:47 pm
cheers vj888
as Rosie said how did you find the correct title?
VideoJunkie888
#6 Post by VideoJunkie888 » Tue Dec 30, 2014 3:55 pm
rosie wrote:Thanks VideoJunkie888!
Cheers!
Hi Guys, I've been offline over Christmas... glad that worked for you rosie...
As for how I identified the correct playlist...
I followed the tip provided by this guy: (thanks dannyboy48888) :arrow: http://www.makemkv.com/forum2/viewtopic ... =45#p33998
...But I see that matt198t already found that thread in a later post...
Hope it helps you too in the future too. :D
beat-breaker
#7 Post by beat-breaker » Wed Dec 31, 2014 11:55 am
thanks for this :-) very helpful as I also normally try to work out the playlist from the movie length but this one was all the same length.
anyone know how you work out which is the correct running order for other tricky discs like this?
#8 Post by Woodstock » Wed Dec 31, 2014 4:50 pm
The definitive way is to rip them all, watch the results, and pick the one without the flaws. But that's impractical for most people.
Part of the problem is that many titles have multiple versions, so that the correct play list for one you buy from, say, Walmart in the US won't work for one you buy from Amazon in the UK, or maybe even Target in the US.
