Won't upgrade to v1.9.0
gxpdriver
Post by gxpdriver »
Windows 7 x64
I am not able to upgrade from v1.8.13 to v1.9.0. The installation process says it was successful, but when I open makemkv, it still states it is v1.8.13. I have also tried to manually uninstall v1.8.13 and then run the v1.9.0 installer.
Thanks,
Chad
Ant93
Re: Won't upgrade to v1.9.0
Post by Ant93 »
Try using IObit Uninstaller (Google it) to completley remove MakeMKV and then install the new version, if this doesn't work then there's obviously a serious problem with your computer! :mrgreen:
