No chapters by default selection?
jack123
Post by jack123 »
Is there a way in the selection rule (or elsewhere) to have no chapters selected by default?
thanks
jack
Re: No chapters by default selection?
Chapters or Titles? Chapters are defined in a track within each file.
If you don't want any titles selected, you can RIGHT-click on the left hand window after the disk is open, and select "deselect all" from the context menu....
jack123
Post by jack123 »
Sorry Woodstock - I did mean to say subtitles. Doing too many things at once I guess.
A button for titles that did the same for sub-titles would be perfect.
You can do subtitles by rule - check the advance section for how to select/deselect audio and subtitle tracks by language. I can't make exact recommendations, because I'm in the opposite situation... needing subtitles most of the time! :)
