Batch converter..
ddiehl
Batch converter..
Post by ddiehl »
I need to convert about 3.5 tb of DVD video_ts folders.. Can someone please recommend an easy to use batch converter to use with MakeMKV.. Want to covert them to single [movie] named files..
Thanks..
Chetwood
Re: Batch converter..
Post by Chetwood »
You've used the search funtion, right?
ddiehl
Post by ddiehl »
Chetwood wrote:You've used the search funtion, right?
Yes I did actually.. Just trying get get an idea which one works best..
Also forgot to mention this is for a Windows machine..
Chetwood
Post by Chetwood »
Just try the versions you find and take the one that works better for you.
