Tree of Life
awoell
Tree of Life
#1 Post by awoell » Tue Dec 16, 2014 12:15 pm
I've been driving myself crazy with this one. This disc looks pristine, so I doubt it's a read error. It's with a new Samsung drive I've only had a few months and haven't had issues with. I've noticed a trend among films by Paramount: Anchorman 2, Wolf of Wall Street, etc. Has anyone else noticed this? I get the same error for those discs as well. It ALWAYS fails. Here's the debug code:
Debug log started at Tue Dec 16 02:57:15 2014 , written by MakeMKV v1.9.0 darwin(x86-release)
001005:0000 MakeMKV v1.9.0 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/alexwoell/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506CB TS00d" opened in OS access mode.
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=8aHdLr6EPS+3xzGFYmR7Tip8IRXDJ+cwClrEr/0OGjrgZOXdvmuMZ1HhK6b+nEaeTila9JqPJk5uBQAdQES3mXFP0ihIj4E6So+SKPViHDUq7z0YIcSbgMUEUHfAb5N5owN+vLenEzeIJ3PvxTb58zFFHheje6ercg==
DCE=F56cRN7wtYVy4c/FLU8kVWmw9sJH3WXtiu2T0QZl1aby2bClY8LBxB+5bDx4Ezuaqg8JepwphdbPfQfWlTWsWC0/lwVoSrWvntT9CMqTwKe0WkOS58Y0/exLnsqy9tDNEa1txwCUQengcVHgaw1WNEqY6/oCOv/TmQ==
003317:0000 Loaded 33 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
SVQ: generic005 builtin/00000.svq
003328:0000 BD+ code processed, got 1 FUT(s) for 1 clip(s)
DISCID=2DE36E418D00A5EB6F5676E4FE43DFFE7FD3E53C
003025:0000 Title #00001.mpls has length of 76 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003307:0000 File 00851.mpls was added as title #0
003025:0000 Title #00405.mpls has length of 15 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003309:0000 Title 00800.mpls is equal to title 00851.mpls and was skipped
003025:0000 Title #00003.mpls has length of 128 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003309:0000 Title 00850.mpls is equal to title 00851.mpls and was skipped
003025:0000 Title #00720.mpls has length of 35 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003307:0000 File 00004.mpls was added as title #1
003309:0000 Title 00801.mpls is equal to title 00851.mpls and was skipped
003025:0000 Title #00003.m2ts has length of 128 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003025:0000 Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 10 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 14 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 38 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 1 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 23 seconds which is less than minimum title length of 500 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 5 seconds which is less than minimum title length of 500 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/Big Bertha
AV sync issues in /Volumes/Big Bertha/The_Tree_of_Life_t00.mkv
AV sync in 1 at 0:00:00.004 (10.666ms) : 1 early frame(s) dropped at start
001003:0020 DEBUG: Code 1073741829 at #x-ibTGr3v0+qxa(:29393953
001003:0020 DEBUG: Code 2 at |<tnvl}zoIA??==#:213137827
001003:0020 DEBUG: Code 2049 at j'D.A.xp&rb/WnDR:213138333
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '4051513344'
001003:0020 DEBUG: Code 0 at #[fvxFw_#|}fE>q64"|w:121263038
001003:0020 DEBUG: Code 0 at |#BDWd;;gSWL#?SF^?$^:121261888
001003:0020 DEBUG: Code 0 at #[fvxFw_#|}fE>q64"|w:213130559
001003:0020 DEBUG: Code 1978278 at #[fvxFw_#|}fE>q64"|w:29393286
001003:0020 DEBUG: Code 0 at A8n%qaCAO/eaM@T2R8y!%:213135090
001003:0020 DEBUG: Code 0 at XIPlNLAc9WySHN'>F89:29396414
:213130950
001003:0020 DEBUG: Code 2281701379 at |<tnvl}zoIA??==#:213134699
001003:0020 DEBUG: Code 268435459 at f*`2c9R83]$NJ[L/v+~ERSg(Y)=:213130950
Re: Tree of Life
#2 Post by Woodstock » Tue Dec 16, 2014 2:44 pm
You may doubt that it is a read error, but your drive disagrees:
If the drive can't read part of a file, MakeMKV can't do a whole lot about that.
SOMETIMES you can get around it by unselecting some audio or subtitle tracks from with the title; If the error happens to be in one of those track, it will be skipped during the rip. However, I must say that I've only had that work twice.
