DTS-MA to FLAC fails in 1.9.0 for some titles
TheShoe
Post by TheShoe » Tue Dec 16, 2014 3:58 am
Hi all -
I've converted many DTS-MA tracks to FLAC successfully except for the following so far:
Band of Brothers (all episodes)
Led Zeppelin Celebration Day
I'm sure I'll find more.
Has anyone else encountered this?
Here's the debug code I see:
DEBUG: Code 356 at `?a-K5{`fCno#?y[:121265522
DEBUG: Code 1 at IU0dy!-B_nD66*X/0E:213136654
DEBUG: Code 0 at IU0dy!-B_nD66*X/0E:29400669
This is using the OSX v1.9.0 version on Mavericks.
The Masked Onion
Re: DTS-MA to FLAC fails in 1.9.0 for some titles
Post by The Masked Onion » Tue Dec 16, 2014 9:12 am
Send a test dump of both discs to makemkv support. /onlinehelp/testdump.html
TheShoe
Post by TheShoe » Sun Dec 21, 2014 12:29 am
Here's the link to the dump file:
[downloaded]
TheShoe
Post by TheShoe » Tue Jan 13, 2015 1:58 am
Any thoughts on this?
Curious if the dump file helped at all....
Post by mike admin » Wed Jan 14, 2015 12:06 pm
Thanks for sending the dumps, and I do apologize for the long response time. This is a bug in MakeMKV, but the bug is a "user interface" bug. If you look at the detailed log file (as written by MakeMKV), you will actually see the reason for the error:
DTS001: Using dtsdecoderdll.dll version 1.1.0.1@2009/02/11 from /Users/xxx/decoders/dtsdecoderdll.dll
DTS001: Launching /Applications/MakeMKV.app/Contents/MacOS/mmdtsdec
DTS001: MakeMKV DTS-HD decoder v1.9.0 darwin(x86-release)
DTS001: DLL: Channels=6 Bits=16 Rate=48000 Mask=f/60f
DTS001: DLL: Using DLL version 1.1.0.1@2009/02/11 from /Users/xxx/decoders/dtsdecoderdll.dll
DTS001: DLL: This stream can't be properly decoded by this DLL, please use dtsdecoderdll v1.1.0.5 or later.
DTS001: DEBUG: code=00000000 src=;OR4-Bg5pL_0Jvo|:121263452
DTS001: Error: Failed to decode
The text at /dtshd/ states that any version of dtsdecoderdll works fine. This turned out not to be the case, as for certain 16-bit DTS-HD streams a recent version of the decoding DLL is required. All you need it to get a version of dtsdecoderdll.dll that is less than 5 years old :) . Specifically, version 1.0.0.8 is popular and easy to acquire.
The next version of MakeMKV will produce clear error message. Once again, sorry for the long response time.
Post by Woodstock » Wed Jan 14, 2015 7:33 pm
Mike, when you update the dtshd page, you probably should remove references to Arcsoft TMT, since it is no longer available.
TheShoe
Post by TheShoe » Wed Jan 14, 2015 11:56 pm
Doh! Missed that in the logs. Thanks much
Also - you meant v1.1.0.8 i assume :)
TheShoe
Post by TheShoe » Thu Jan 15, 2015 1:07 am
given I've been using a pretty old version, is it worth re-converting the DTSMA tracks to FLAC again?
have no idea the change-log from 1.1.0.1 to 1.1.0.8, but clearly there have been changes!
Romansh
Post by Romansh » Thu Jan 15, 2015 6:04 pm
TheShoe wrote:given I've been using a pretty old version, is it worth re-converting the DTSMA tracks to FLAC again?
It's either lossless or it isn't, so no need to re-convert the tracks that were already successfully converted.
