Video from Blu-ray can't be synced to iPhone 3GS in iTunes
star-affinity
Post by star-affinity »
Like this: Blu-ray disc > MakeMKV > MKV file > iFFmpeg > MP4 file
That MP4 video I get won't sync in iTunes to my son's iPhone 3GS because it says it can't be played back on that device. If I make an MKV of a DVD and then convert the MKV to MP4 there's no problem.
I know there are other video players that will play back the file, but I prefer to use the built-in (Apple's) because it seems to be the most efficiant. I have VLC too, but it struggles with the videos even if they have been converted to 640 x 480.
Any ideas why the MP4's made from Blu-rays won't play back (i.e. won't sync) to the iPhone 3GS (running iOS 6) from iTunes?
Romansh
Re: Video from Blu-ray can't be synced to iPhone 3GS in iTun
Post by Romansh »
Ask iFFmpeg support.
Are yo sure whatever settings you're using actually downscale the content? The iPhone 3GS cannot play high-defnition videos, it's limited to 720x576 up to 25 fps, 720x480 up to 30 fps…
star-affinity
Romansh wrote:Ask iFFmpeg support.
Thanks for your reply!
Yes, they are 640 x 480. I have contacted them and they gave me different presets top try, but no go. The same presets work for a DVD that I run through MakeMKV, but for Blu-rays I get the problem that they won't sync to the iPhone 3GS in iTunes because it is said the file can't be played.
There is also the issue with audio CODECs that Bluray has but aren't supported on the 3GS...
Romansh
Post by Romansh »
Maybe if you post a MediaInfo report of two example files (DVD -> MakeMKV -> iFFmpeg -> output.mp4, BD -> MakeMKV -> iFFmpeg -> output.mp4) we can spot the culprit.
star-affinity
Sorry for late followup.
I'll try to gather Mediainfo reports for the two files as suggested. I probably won't have time until next week.
Thanks so much for trying to help – you are awesome! :)
Edit
Here we go – hope you can find something.
Works to sync:
General
Complete name : /Volumes/Data2/Video Factory/iFFmpeg-RIPs/Vem.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
File size : 210 MiB
Duration : 30mn 4s
Overall bit rate : 979 Kbps
Encoded date : UTC 1904-01-01 00:00:00
Tagged date : UTC 1904-01-01 00:00:00
Writing application : Lavf56.4.101
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 30mn 4s
Bit rate : 780 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.075
Stream size : 168 MiB (80%)
Writing library : x264 core 142
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x1:0x130 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=8 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 30mn 4s
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 41.4 MiB (20%)
Title : Stereo
Language : Swedish
Menu #1
Codec ID : text
Duration : 30mn 4s
Language : English
Bit rate mode : CBR
00:00:00.000 : Chapter 01
00:04:20.240 : Chapter 02
00:07:50.960 : Chapter 03
00:11:23.120 : Chapter 04
00:15:00.080 : Chapter 05
00:18:35.120 : Chapter 06
00:22:10.160 : Chapter 07
00:25:47.120 : Chapter 08
00:30:02.000 : Chapter 09
Menu #2
00:00:00.080 : Chapter 01
Doesn't work to sync:
General
Complete name : /Volumes/Data2/Video Factory/iFFmpeg-RIPs/Wall•E.m4v
Format : MPEG-4
Codec ID : M4V
File size : 542 MiB
Duration : 1h 38mn
Overall bit rate : 767 Kbps
Movie name : Wall•E
Performer : Andrew Stanton
Recorded date : 2008
Writing application : Lavf56.15.102
Video
Format : AVC
Format profile : Baseline@L3.1
Format settings, CABAC : No
Codec ID : avc1
Duration : 1h 38mn
Bit rate : 635 Kbps
Width : 640 pixels
Height : 480 pixels
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.086
Stream size : 448 MiB (83%)
Writing library : x264 core 142 r2479 dd79a61
Encoding settings : cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x1:0x130 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=8 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=24.0 / qcomp=0.60 / qpmin=3 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1h 38mn
Bit rate : 128 Kbps
Stream size : 90.5 MiB (17%)
Language : English
Menu #1
Codec ID : text
Duration : 1h 38mn
Language : English
Bit rate mode : CBR
00:03:36.320 : Chapter 02
00:05:49.704 : Chapter 03
00:09:18.788 : Chapter 04
00:12:03.452 : Chapter 05
00:17:56.471 : Chapter 06
00:19:33.402 : Chapter 07
00:21:10.165 : Chapter 08
00:23:46.821 : Chapter 09
00:29:18.027 : Chapter 10
00:31:25.113 : Chapter 11
00:33:27.777 : Chapter 12
00:35:20.139 : Chapter 13
00:38:49.557 : Chapter 14
00:42:53.383 : Chapter 15
00:43:31.672 : Chapter 16
00:51:08.962 : Chapter 17
00:52:07.604 : Chapter 18
00:54:47.472 : Chapter 19
00:56:05.800 : Chapter 20
00:57:58.037 : Chapter 21
00:58:41.205 : Chapter 22
01:02:14.919 : Chapter 23
01:03:21.068 : Chapter 24
01:05:49.717 : Chapter 25
01:11:44.905 : Chapter 26
01:15:54.237 : Chapter 27
01:19:22.821 : Chapter 28
01:20:14.706 : Chapter 29
01:24:14.112 : Chapter 30
01:25:45.787 : Chapter 31
01:30:17.516 : Chapter 32
Menu #2
00:00:00.021 : Chapter 01
