expendables 3 source file
mariog
Re: expendables 3 source file
Hello All,
I am new.
I have a different bluray. the one which includes the unrated version,, the playlist do not correspond as the one posted here previously...and powerdvd 10 launches a wrong playlist.
does anyone has the bluray that has theatrical version and extended unrated version and know which mpls is?
if you need further details let me know.
I am new.
penguinsaregood
The source for the unrated version from Amazon (UPC: 0 31398 20636 1).
I did not care about the theatrical version.
Title information
Name: Expendables 3 (English)
Source file name: 00756.mpls
Duration: 2:11:31
Chapters count: 16
Segment count: 17
Segment map: 280,284,299,277,292,276,290,289,294,312,298,295,285,296,279,281,286
File name: Expendables_3_t08.mkv
zoxxo
I like to rip both. The unrated version that I have matches what penguinsaregood found. I found two tracks that matched the theatrical version, but I was not able to determine which track was the right one...penguinsaregood wrote:The source for the unrated version from Amazon (UPC: 0 31398 20636 1).
I did not care about the theatrical version.Title information
Duration: 2:11:31
Chapters count: 16
Segment count: 17
ASX147
any knows which pc based soft player can read that damn atmos track or the core ? aurora does not.
very frustrating
thanks
very frustrating
thanks
MuckleEck
All,
I have the Expendables 3 Extended Edition that has Segment Maps starting in 333 anybody any idea which of the 8 files I should rip or just do the whole lot!
Spiritvs
Only PowerDVD 14 decodes Atmos.ASX147 wrote:any knows which pc based soft player can read that damn atmos track or the core ? aurora does not.
very frustrating
thanks
MuckleEck
All,
For those that have the Expendables 3 Extended Version UK
The correct feel is No 00000.mpls with corresponding mts order of
333, 315, 318, 313, 332, 311, 316, 320, 327, 310, 322, 328, 335, 329, 312, 326
beat-breaker
I'm trying to copy my Expendables 3 to play on my Media PC with MPC-HC.
I've correctly identified the movie, both theatrical and extended versions using the AnyDVDHD trick to locate the mpls files.
They successfully copied using MakeMKV 1.9.0 (x64)
When I try to play them, the screen is black and playback is stuck at the start, pausing, playing does nothing.
If you manually jump to anything beyond the 00:00 then it will play but without sound (I only rip with HD Audio, 7.1 in this case)
When I try to play the actual disc using MPC-HC it also doesn't play / have sound in the same way as with the mkv files.
I assume this means it's an issue with MPC-HC and not MakeMKV, but just wanted to check here as it seems a troublesome disc!
Anyone here had success with MPC-HC playing the UK Extended version with Digital copy (bar code 5 055761 903508) as a disc and/or MKV rip with HD Audio?
thanks
thanks
beat-breaker
I found a solution to this!
https://trac.mpc-hc.org/ticket/4879
https://github.com/Nevcairiel/LAVFilters/releases
d/l latest version of MPC-HC from the nightly build link at bottom of the 1st link I posted
update LAV to latest versions
now it ignores the atmos flags and plays the movie with True HD 7.1
VideoJunkie888
INFO:
The Expendables 3 [2014] : (Theatrical & Extended Edition)
* Bluray Version = UK Retail
> Protection: AACS v49
Disc Information
Label: EXPENDABLES_3
Timestamp: 2014-10-21 17:32:51
Data capacity: 44.77 Gb
Disc type: BD-ROM
Number of layers: 2
Bus encryption flags: 80
NOTE:
** the FOLLOWING playlists are correct only for the ABOVE bluray disc version)...
Checked and verified as correct playlist(s):
EXTENDED PLAYLIST:
(Extended Version) 2:11:31 = 701.mpls
Title information
Source file name: 00701.mpls <- (Correct playlist for Extended Edition)
Duration: 2:11:31
Chapters count: 16
Segment count: 17
Segment map: 333,330,318,319,332,321,316,314,327,317,322,323,328,325,329,331,326
File name: Expendables_3_t**.mkv <- (varies dep. on your MakeMKV min. length setting)
THEATRICAL PLAYLIST:
(Theatrical Version) 2:06:27 = 436.mpls
Title information
Source file name: 00436.mpls <- (Correct playlist for Theatrical Edition)
Duration: 2:06:27
Chapters count: 16
Segment count: 17
Segment map: 333,315,318,313,332,311,316,320,327,310,322,309,328,335,329,312,326
INFO:
To locate the correct ".mpls" playlist within MakeMKV, simply watch the "source file name" field value within MakeMKV's information panel (whilst scrolling through all the dummy playlist entries) until you are selecting the correct playlist(s) shown above!
ADDITIONAL:
This disc uses the new HD audio format "Dolby TrueHD Atmos", which (currently) is unsupported by HandBrake...
If you intend on further transcoding your ripped MakeMKV .mkv file within HandBrake - it is wise to also rip the Dolby Digital (Core Audio) sub-stream (which HandBrake can process).
Disc Information
Disc type: BD-ROM
Number of layers: 2
NOTE:
EXTENDED PLAYLIST:
Title information
Duration: 2:11:31
Chapters count: 16
Segment count: 17
Title information
Duration: 2:06:27
Chapters count: 16
Segment count: 17
INFO:
ADDITIONAL:
matt198t
good stuff junkie
VideoJunkie888
No probs mate...matt198t wrote:good stuff junkie
I have decided that I will provide this type of information for any and all bluray discs that I come across (i.e. "legally purchase") that use this type of annoying restriction to discourage its ridiculous adoption by the industry...
To enable legitimate customers to rip a legal backup to their own home multimedia centres.
So if you are UK based, there is a decent chance I will be able to help you out in this way in future (if I also purchase the same disc)...
...and I would encourage others (with other disc versions) to do the same!
See how to:
Blue407
Worked for meMuckleEck wrote:All,
charlie2025
Confirmed by playing in bluray player and noting length and chapter timing.
UPC 3139820636
Theatrical:
Source file name: 00007.mpls
Duration: 2:06:27
Chapters count: 16
Segment count: 17
Segment map: 280,291,299,297,292,288,290,293,294,282,298,278,285,300,279,287,286
File name: Expendables 3.mkv
Unrated Edition:
Duration: 2:11:31
Chapters count: 16
Segment count: 17
UPC 3139820636
Theatrical:
Duration: 2:06:27
Chapters count: 16
Segment count: 17
Unrated Edition:
Duration: 2:11:31
Chapters count: 16
Segment count: 17
