Errors with Captain America - The First Avenger
SoCalChip
Post by SoCalChip »
I am trying to create an MKV file of Captain Americe - The First Avenger on my Windows 7 PC. I am using MakeMKV v 1.8.9 win x64. I keep running into errors with this disk. I have tried cleaning the disc, first with eyeglass cleaner and a lens cloth then with pledge polish. I still run into errors. Below is a copy of the log of my last attempt. I do not think it is the drive or my PC because I ripped multiple blu-rays before and after this attempt.
Saving 1 titles into directory F:/ using profile 'AAC-stereo' from file 'C:\Program Files (x86)\MakeMKV/aac-stereo.mmcp.xml'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '14141227008'
DEBUG: Code 0 at /.AgN(8y9/!T/\dw\N<a:121262739
DEBUG: Code 0 at af*rc"L-UVHqhIYkW/3X:121261888
DEBUG: Code 0 at /.AgN(8y9/!T/\dw\N<a:213130743
DEBUG: Code 6904896 at /.AgN(8y9/!T/\dw\N<a:29393332
DEBUG: Code 20 at q(DWoY',='eg;a`":29395310
DEBUG: Code 0 at q(DWoY',='eg;a`":121264648
DEBUG: Code 0 at /.AgN(8y9/!T/\dw\N<a:29393332
DEBUG: Code 0 at 4B]c|4QICi*@I$*"H5MO:121263245
DEBUG: Code 0 at vZA2<~8)qjS^6B.w_;t^q:121266810
DEBUG: Code 0 at /.AgN(8y9/!T/\dw\N<a:121261865
DEBUG: Code 0 at vZA2<~8)qjS^6B.w_;t^q:29399082
Failed to save title 0 to file F://Captain_America_The_First_Avenger_t00.mkv
0 titles saved, 1 failed
File 00800.mpls was added as title #0
Title #01000.mpls has length of 90 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #01001.mpls has length of 90 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #00020.mpls has length of 96 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #00250.m2ts has length of 300 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #01007.m2ts has length of 14 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #01008.m2ts has length of 14 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #01009.m2ts has length of 14 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #01010.m2ts has length of 45 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #01011.m2ts has length of 45 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #00051.m2ts has length of 11 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #00053.m2ts has length of 11 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #00021.m2ts has length of 48 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Title #00022.m2ts has length of 48 seconds which is less than minimum title length of 700 seconds and was therefore skipped
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '14145945600'
DEBUG: Code 6907200 at /.AgN(8y9/!T/\dw\N<a:29393332
I changed my preferences and increased the Read retry count to 11. I notice when the rip is about halfway done my drive starts to make noise like it is skipping over a track. There are a couple of small visible scratches on the disk.
I saw another post that commented that there is different sofware that may be better at ripping a scratched disk than MakeMKV. Any suggestions would be appreciated. I quickly scanned the movie on a blue-ray player (watching 3 seconds of a chapter then skipping) and it seemed to work. I will next watch a few chapters in their entirety to make sure the disc plays OK.
Re: Errors with Captain America - The First Avenger
Scratches can be a big problem, especially with BDs. With a DVD, you lose less data to the same size scratch, and SOMETIMES, switching to a DVD drive with its different-wavelength laser can see through well enough to do the rip.
If you don't have access to someone with an actually disk refinishing system, the next step beyond what you've done is the "toothpaste treatment". You want a medium-abrasion paste, a clean finger and some water. With a wet finger with some toothpaste on it, gently work in a circular around the scratches.
Do NOT go overboard with this; proper resurfacing should be done with proper equipment, and this isn't it!
Rinse thoroughly, and wax the disk again.
If it still gives errors, check with DVD rental places (assuming they haven't all gone away in your area) about paying them to polish the disk.
