MakeMKV Error DEBUG: Code 0 at IqH&<Iv30Q5zp#<9MN@%:29394574
Toxifera
Post by Toxifera »
Hello out there,
I am new to MakeMKV so please bear with me. I am trying to make an MKV file from a blu ray "Wolf Children". I am using a older Sony BWU-500S burner with a 7200 rpm Seagate ST32000641AS HD. This is the first Blu Ray I have attempted to rip. After about 10 minutes into the process I start getting a few '002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages". Then shortly after I start getting "DEBUG: Code 0 at IqH&<Iv30Q5zp#<9MN@%:29394574 The source file '/BDMV/STREAM/00001.m2ts' is corrupt or invalid at offset 11443372032, attempting to work around". This message is reported over and over again. Then the time keeps increasing until it is hours before it finishes. I then usually manually stop the process. What can I do to resolve this problem? Thanks in advance for any replies.
Re: MakeMKV Error DEBUG: Code 0 at IqH&<Iv30Q5zp#<9MN@%:2939
The first warning just tells you that you COULD get better performance if your computer could write to disk faster; MKV is waiting to write what it reads from the BD drive.
I've only got the DVD version of this title, so I can't say if the other work-around messages are "normal" for it; they're letting you know that MakeMKV had to do something non-standard to read the data. As long as the offset is changing, the work-arounds are effective, but it does slow things down. If they repeat constantly at the same location, there is an issue with the disk.
Some publishers have a LOT of messages like this on the BD titles. Debug logs from NISAmerica titles can be VERY long.
Toxifera
Post by Toxifera »
Hey Woodstock,
Thanks for the reply. The offset does change every 20 or 30 repeats. This time I changed the profile from default to AAC and it ran without any errors until it hit 90%. Then the errors started and continued for about 4 minutes and the program froze.
Would a mSATA SSD be wise to install as a source in combination with a newer BD burner?
Thanks again.
Post by mike admin »
Please try making a full disc backup and see if any hashcheck errors show up.
An SSD is not necessary, because conventional hard drives can normally keep up quite well.
Toxifera
Post by Toxifera »
Hey Mike,
Thanks for the reply. I have tried several times but the process never finishes without MakeMKV freezing. I did order a new Pioneer BD Burner to see if it will help.
Hey Woodstock,
I thank you for trying to save me some cash, but I have always wanted to play with a SSD. I have a slot on my MB for a mSATA, so I purchased a inexpensive 250Gb one.
Thanks again guys for helping.
Oh, a different kind of "need", which I totally understand! My old Dell i8500 laptop recently received a flash boot drive upgrade, even though I rarely use it. :)
Toxifera
Post by Toxifera »
Hey Woodstock & Mike,
The new blu ray drive & SSD worked like a charm. It took 24 minutes to rip Wolf Children without a hitch :D . Thank you guys for your suggestions and help. I hope you have a Very Merry Christmas & a great New Year. Have a good one,
Eric
