AACS v49
stryker
AACS v49
Post by stryker »
Edit: Nevermind, it just took ~20mins to decrypt the disc apparently.
Did you skip AACS v49? because it doesn't seem to work.
OS device name: \Device\CdRom7
Product: BD-RE BP40NS20
Revision: ML01
Firmware date: 2011-09-07 12:34:56
Bus encryption flags: 1F
Highest AACS version: 49
Disc Information
Timestamp: 2014-10-17 14:34:58
Data capacity: 36.34 Gb
Disc type: BD-ROM
Number of layers: 2
Re: AACS v49
For future information, if MakeMKV encounters a version of AACS it doesn't support yet, it will give you a link to click on to report the new version. That link encodes information about the AACS so that Mike can update the program.
AACS is pretty much cumulative - if you work with v50, v49 and older are also covered.
