Grimm Season 3 Blu-Ray Disc Error
Sunset1982
Post by Sunset1982 »
Hi!
I've tried to rip the "Grimm season 3" blu-ray, but when the selceted parts are ripped, the are only playable for some minutes untill the playback stops. Every file is only playable until a special point where the video stops playing. sound plays fine and will go on playing.
I used makemkv 1.9.0. Any ideas?
Re: Grimm Season 3 Blu-Ray Disc Error
What playback device/software? You may be encountering "Cinavia watermark protection". http://makemkv.com/forum2/viewtopic.php?f=1&t=1846
Software players like VLC ignore Cinavia, so playing the files with VLC should confirm if it is the file that is a problem or copy protection.
Sunset1982
i'll test it and report the results...
Sunset1982
VLC does NOT work too, so it seems that it is not the copyprotection.
ndjamena
Post by ndjamena »
Do a backup and see how many M2TS files each episode is made up of. See if each M2TS file will play in VLC on it's own.
gexter
Post by gexter »
I have the same Problem with Season 3 of Grimm....
10 Minutes working and then VLC stops playing.
What can I do?
Greets
Debug logs from the rip of the disk would help. Usually, they'll have the clues to why the playback is not working.
FAQ link in my signature will help you get the debugging logs.
gexter
Post by gexter »
Yep - ik.
Trying to rip the 3rd disk with logging the debug.
Post follows in some minutes. :)
Thanks for your answer.
gexter
Post by gexter »
And there you have it:
Debug log started at XXX , written by MakeMKV v1.9.1 win(x64-release)
001005:0000 MakeMKV v1.9.1 win(x64-release) gestartet
001004:0000 Debug-Aufzeichnung eingeschaltet. Aufzeichnung wird gespeichert als C:\Users\XXXXXX/MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at `|<T"dbf@uC2lNEo:213137827
001003:0020 DEBUG: Code 100809218 at 5C"5|V)_l/F7(vh[%%:213132100
001003:0020 DEBUG: Code 100809218 at 5C"5|V)_l/F7(vh[%%:29393930
002003:0000 Fehler 'SCSI-Fehler - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' trat auf während des Auslesens von 'BD-RE HL-DT-ST BD-RE  BH16NS40 1.01' bei Offset '524288'
002003:0000 Fehler 'SCSI-Fehler - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' trat auf während des Auslesens von 'BD-RE HL-DT-ST BD-RE  BH16NS40 1.01' bei Offset '1048576'
002003:0000 Fehler 'SCSI-Fehler - NOT READY:MEDIUM NOT PRESENT - TRAY OPEN' trat auf während des Auslesens von 'BD-RE HL-DT-ST BD-RE  BH16NS40 1.01' bei Offset '32768'
001003:0020 DEBUG: Code 0 at }tdh#~-A6N> /_$_/_=:213129777
003007:0000 Direkter Zugriffsmodus wird verwendet
005053:0308 Sie verwenden den erweiterten Funktionsumfang der Sharewareversion. Sie können das Programm 30 Tage ausprobieren. Danach müssen Sie einen Aktivierungsschlüssel erwerben, wenn Ihnen diese Software gefällt und Sie die Funktionen weiterhin nutzen möchten. Möchten Sie den Testzeitraum jetzt beginnen?
005050:0000 Evaluierungsversion. Es verbleiben noch 30 von 30 Tagen.
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=PC7Jrh4YXdwCOsSdYDbwxktq4LTz7dwF6oBPN3/wVCrLiengk3QfypF+4SvgJ7iGSU7YNYUO2rKrGy4+6lZJkbhGhqYtKmWoRkSAJ42dRWTf06uFLEz0/GP0Dy0BjUXOx8RQ+0h1j9kcJZFn8Fi4Y3Z/h3Zh49CJ/g==
DCE=RDzYaJwh9nuimwymJWYrUL3Nrb5oBM08ZIj0dQ6Fpnu5DAQ5vtM1rqXikcMAOs63RreVg4tLgpHVDY7m48h3JSvTm0ZFNJYu7qVxXqHUe2oPFxsKsMy7KnS6RtJ6p4faJoZ3HDtYAmFG+ZSUnOEk0sGiF1E78AXZDw==
DISCID=DC9E24C5FCF7BAAC3C4FB4A7331AE1FBD92BE536
003307:0000 Datei 00004.mpls wurde als Titel 0 hinzugefügt
003307:0000 Datei 00003.mpls wurde als Titel 1 hinzugefügt
003307:0000 Datei 00002.mpls wurde als Titel 2 hinzugefügt
003307:0000 Datei 00001.mpls wurde als Titel 3 hinzugefügt
003307:0000 Datei 00000.mpls wurde als Titel 4 hinzugefügt
003025:0000 Titel #00009.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003307:0000 Datei 00006.m2ts wurde als Titel 5 hinzugefügt
003025:0000 Titel #00008.m2ts hat eine Länge von 25 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
003025:0000 Titel #00007.m2ts hat eine Länge von 10 Sekunden und wurde übersprungen, da die minimale Titellänge 120 Sekunden beträgt
001003:0020 DEBUG: Code 233 at RHtQzqil57cODaVcmPVZqOze:0
001003:0020 DEBUG: Code 233 at xrVliJ7EQCaWknlUVgcmE1hx:0
001003:0020 DEBUG: Code 233 at KYgxXdKMWxHuKMfUuEpVivsE:0
001003:0020 DEBUG: Code 233 at 38YG08zcBYQ+y+dfsZlfPBMa:0
001003:0020 DEBUG: Code 233 at MSqxRGrA/ub+ftlGFb3Ualvq:0
001003:0020 DEBUG: Code 233 at mTVaxA1IvOsu1JTVB3UMwJR9:0
001003:0020 DEBUG: Code 233 at VM6R8Pn+MmNpJwzqBBGd4a0w:0
001003:0020 DEBUG: Code 233 at bGXu43uCEAjuV38wWQmKfhfn:0
001003:0020 DEBUG: Code 233 at NrU5Y5jWM2EA31bI2hNXHa5j:0
001003:0020 DEBUG: Code 233 at yd8seTbDAlSUqy2/VFYAEP8c:0
005011:0000 Die Aufgabe wurde erfolgreich abgeschlossen
005014:0000 5 Titel werden in Verzeichnis B:/Video/GRIMM_S3_D3 gespeichert
005005:0080 5 Titel wurden gesichert
005036:0104 Das Kopieren wurde abgeschlossen. 5 Titel wurden gesichert.
Application exited at XXX
Thanks for your help. :)
The " NOT READY:MEDIUM NOT PRESENT - TRAY OPEN " errors in the middle of things are a bit confusing.
In this case, Mike will have to interpret the debug codes. They show where things were not as expected, and various work-arounds were applied to make sense of the data.
gexter
Post by gexter »
How can I contact him?
Mike is the administrator of the board here. He'll see your message within the next few days, but... email to support@makemkv.com is the quickest way to get in touch. See the FAQ in my signature for the first things he's going to need besides the debug log information.
McStarfighter
Post by McStarfighter »
For me it is very strange that remuxing to MKVs via DVDFab is running without any problems ... The MKVs are running smoothly ...
sandsack
Post by sandsack »
Is there a solution to this issue. I see exactly the same. Ripping the BD seems to be ok but files are way to small. While in VLC the duration is e.g. 53 minutes, after 15 minutes picture freezes. So it seems that MakeMKV does not do a correct job.
Solution? Other "free" or inexpensive tools than work on Grimm BD?
laala
Post by laala »
I have the exact same problem. Grimm Season 3 Blu-rays with MakeMKV 1.9.7.
Is it some kind of new copy protection?
