The Day The Earth Caught Fire
Roger Weir
#1 Post by Roger Weir » Sat Nov 29, 2014 10:29 pm
Hello.
The ripping process fails when reading this new Blurray;
OSX Yosemite 10.10.1
MakeMKV v 1.9.0
Process stops when reading /AACS/MKB_RO.inf
Any suggestions. I can watch the disk on my Mac fine. Other disks seem OK too.
Roger
Re: The Day The Earth Caught Fire
#2 Post by Woodstock » Sun Nov 30, 2014 6:43 am
Logs would help.... Without them, the current guess is, "Something's broken".
Roger Weir
#3 Post by Roger Weir » Sun Nov 30, 2014 11:47 am
OK, enabled logging. Thought I'd leave the process running a lot longer today for the test, and after almost 5 minutes it seems to have continued. I'm now converting the files and will post again regarding how successful it was.
Thanks for the pointers so far.
Roger
Roger Weir
#4 Post by Roger Weir » Sun Nov 30, 2014 1:02 pm
Yep, all fine. All 12 titles are viewable.
Log is below for interest.
Debug log started at Sun Nov 30 11:38:51 2014 , written by MakeMKV v1.9.0 darwin(x86-release)
001005:0000 MakeMKV v1.9.0 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/rogerweir/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5680H 3AHBd" opened in OS access mode.
002010:0000 Optical drive "BD-ROM PIONEER BD-ROM BDC-203 1.10d" opened in OS access mode.
DAFD=PAAAADAAAAEABDQUEAQEBAQ==
DCE=vP/8/Xjl00B3+qWLgYNrlbj/Owsqfhw8YK/csFpLwxa3TnzmYCYHMWz04+Xo095XR17Jp49kueSyVQggYrd7Gv4BOiO5x7c/mEA2Or60UYMgK0Bn/nnIw/SzqS9TY1UV0X3ZRdnDWfLByM0Nyco2No4gt6+UPUdHLQ==
DISCID=57BD6F07E5FD05B8D78A61A1F5039D831F139050
003307:0000 File 00021.mpls was added as title #0
003307:0000 File 00019.mpls was added as title #1
003307:0000 File 00020.mpls was added as title #2
003307:0000 File 00003.mpls was added as title #3
003307:0000 File 00002.mpls was added as title #4
003307:0000 File 00018.mpls was added as title #5
003307:0000 File 00001.mpls was added as title #6
003307:0000 File 00015.mpls was added as title #7
003025:0000 Title #00010.mpls has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00009.m2ts was added as title #8
003025:0000 Title #00024.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00008.m2ts was added as title #9
003307:0000 File 00019.m2ts was added as title #10
003025:0000 Title #00025.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00018.m2ts was added as title #11
003025:0000 Title #00001.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 12 titles into directory /Users/rogerweir/Movies/Earth
004001:0000 Forced subtitles track #4 turned out to be empty and was removed from output file
AV sync issues in /Users/rogerweir/Movies/Earth/title07.mkv
AV sync in 1 at 0:01:00.291 (3.666ms) : short audio gap was removed, audio skew is -3.666ms
AV sync in 1 at 0:01:31.427 (34.333ms) : audio gap - 1.072 missing frame(s)
AV sync in 1 at 0:02:01.625 (22.666ms) : short audio gap was removed, audio skew is -22.666ms
005005:0080 12 titles saved
005036:0104 Copy complete. 12 titles saved.
Application exited at Sun Nov 30 12:49:36 2014
westham
#5 Post by westham » Fri Jan 30, 2015 11:20 am
I am having problems with this one too. With an MKV file the issue seems to be with the soundtrack. If I rip with both tracks (mono for the film and stereo for the commentary) I get the following:
Mono: Film is speeded up to almost double speed on playback
Stereo: All fine!
With a full ISO/folder backup the following happens:
Mono: Normal speed playback but audio only comes out of the left speaker
Stereo: All fine
Strange one this, not managed to crack it as yet. Perhaps it is something to do with the mono main track.
#6 Post by Woodstock » Fri Jan 30, 2015 3:21 pm
If you have handbrake, you might want to see what it does with the MKV file.
The problem with working from an ISO file is that there may be problems that were created by whatever was used to make the ISO. Working with MakeMKV directly from the source DVD narrows down what program(s) are responsible.
