Hi, got a highly rip resistant DVD :)!
TrevorS
#1 Post by TrevorS » Mon Nov 10, 2014 6:54 am
The DVD is Parasite (1982), an early "Cult Video" "Full Moon" Demi Moore release (Canada, Koch Vision CUV-DV-8008) and I can't crack it with any of DVDdecrypter, RipIt4Me, or the current version (1.8.14) of MakeMKV. I'm running on Win7 Ultimate Sp1 64bit and BDs have been falling to MakeMKV handily, and likewise most HD DVD and DVD, but this title appears especially resistant.
The symptoms are, with the DVD in the drive, I launch MakeMKV and it presents drive and disc info on the right, but the "Protection:" field to the left is blank. It reports a single layer 4.28GB disc. I click on the drive icon and observe the following messages:
MakeMKV v1.8.14 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Trevor/MakeMKV_log.txt
Title #1 was added (22 cell(s), 1:24:14)
Title #2 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 was added (8 cell(s), 0:16:04)
Title #4 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
No further messages are generated and the elapsed and remaining time indicators just continue to tick the seconds -- at this point it's hung and will continue ticking indefinitely. No progress at all in the "Decrypting data" bar and an unmoving "Opening DVD disc" bar. Below is the debug info for three different drives.
Debug log started at Mon Nov 10 06:34:19 2014 , written by MakeMKV v1.8.14 win(x64-release)
001005:0000 MakeMKV v1.8.14 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Trevor/MakeMKV_log.txt
003028:0000 Title #1 was added (22 cell(s), 1:24:14)
003025:0000 Title #2 has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #3 was added (8 cell(s), 0:16:04)
003025:0000 Title #4 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 1 at xkCailmn1Xuz^:213132422
001003:0020 DEBUG: Code 0 at "VB6KyP\__LRXC5o--:29403383
001003:0020 DEBUG: Code 0 at "VB6KyP\__LRXC5o--:121275688
001003:0020 DEBUG: Code 1 at vz+WZE:Y]A^?rr01:29394413
001003:0020 DEBUG: Code 0 at .L:6,m.@)K8^83a:121270881
001003:0020 DEBUG: Code 0 at OxEN/&g^>jxVf7:29397564
001003:0020 DEBUG: Code 0 at OxEN/&g^>jxVf7:121265614
001003:0020 DEBUG: Code 117506160 at quR2S\ {RizWP!^te{:213132100
001003:0020 DEBUG: Code 117506160 at quR2S\ {RizWP!^te{:29393930
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE PIONEER BD-RW   BDR-208D 1.10' at offset '530432'
001003:0020 DEBUG: Code 0 at 21!wb"W_cgdc,ZKEhzj:29394183
001003:0020 DEBUG: Code 0 at 21!wb"W_cgdc,ZKEhzj:29393930
001003:0020 DEBUG: Code 233 at D1zXbA5qiems9rlhpYjX/wE2:0
Application exited at Mon Nov 10 06:36:15 2014
MakeMKV normally gets along fine with that BD drive, but I tried switching to a DVD drive instead. The same problem appears to occur with both (one USB3.0, the other USB2.0).
Debug log started at Mon Nov 10 06:39:13 2014 , written by MakeMKV v1.8.14 win(x64-release)
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'DVD+R-DL _NEC DVD_RW ND-3550A 1.05' at offset '530432'
001003:0020 DEBUG: Code 233 at IA3iD4TCEoMJmcjsg8c+haTP:0
Application exited at Mon Nov 10 06:40:44 2014
As the above two drives are USB connected, I though I'd try my ATA connected drive as well, but more of the same.
Debug log started at Mon Nov 10 06:45:00 2014 , written by MakeMKV v1.8.14 win(x64-release)
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'DVD+R _NEC DVD+RW ND-1100A 1.B0' at offset '530432'
001003:0020 DEBUG: Code 233 at I0aWt1j1AY+G7VfQCWnwV3uz:0
Application exited at Mon Nov 10 06:46:38 2014
Sure hope you can figure something out on this. Thanks -- Trevor!
PS. I should mention the disc is clean, unscratched (looks new), and plays fine on a standard DVD player.
TrevorS
Re: Hi, got a highly rip resistant DVD :)!
#2 Post by TrevorS » Thu Nov 20, 2014 7:15 am
Just a thought! If there's something I can provide to help resolve this decryption issue, I'd be happy to assist!
ndjamena
#3 Post by ndjamena » Thu Nov 20, 2014 9:16 am
You could try letting it run over night, as far as I can tell the debugs logs are just telling us that you cancelled the scan.
#4 Post by mike admin » Sat Nov 29, 2014 9:24 pm
Please try the following - play the disc on a regular DVD player and note the title number for the main title. Then, try opening the disc with MakeMKV 1.9.0 using new "manual DVD open" mode. Just type the title number into manual string, and see if it works.
Pekka77
#5 Post by Pekka77 » Tue Dec 09, 2014 8:41 pm
mike admin wrote:Please try the following - play the disc on a regular DVD player and note the title number for the main title. Then, try opening the disc with MakeMKV 1.9.0 using new "manual DVD open" mode. Just type the title number into manual string, and see if it works.
I just wanted to say thanks for the tip, worked for me on a dvd that did not behave. What I got without it was just the comersial at the start, not the actual title.
TrevorS
#6 Post by TrevorS » Fri Jan 02, 2015 12:36 pm
Hi Mike,
Sorry about the long delay, I just discovered you had replied to my problem report. Thanks, I just checked the title number. Although entering the title number allowed to skip some other titles and instead go straight to the desired title (1), it then behaved identically to before. After it accomplished nothing for approx eight hours, I tried to read the error log, but it apparently hadn't been closed properly(I/O error 32), so I guess that's a bug itself. Here is what I copied from the screen:
MakeMKV v1.9.0 win(x64-release) started
DEBUG: Code 1 at )G/&h6=NXh+&Q:213132422
DEBUG: Code 0 at (k6{0.r(-:Qd7[xR0Y:29404464
DEBUG: Code 0 at (k6{0.r(-:Qd7[xR0Y:29408489
DEBUG: Code 1 at _^zI&/]<mu(y^SaI:29394413
DEBUG: Code 0 at H`QaCa9O6ozl"Wl:121270881
DEBUG: Code 0 at bI1[?wO-iCDv|-:29398530
DEBUG: Code 233 at oHMLaPBD3UV0LNd76sddiVAw:0
DEBUG: Code 233 at bI6maB8zJL4d7grVTgwFenO9:0
Everything after the "Title #1 ..." message was generated after I stopped the program.
It appears as though MakeMKV can't follow the series of data blocks following the start of the title -- something causes it to get lost and hang. There's no indication that it's actually still running, other than it hasn't formally quit!
