[Help] Cant open disk (SkyFall)
Saner
Post by Saner »
Hiya.
I cant seem to get MakeMKV to work :(. I am trying to use it as a streaming option, but it seems to not want to open my disk(s)
I will put as much info as I think i need to, but if I have left anything out please let me know.
if I run this command it just dumps my back to the cli.
xbmc@xbmc:~$ makemkvcon info disk:0
MakeMKV v1.9.0 linux(x64-release) started
xbmc@xbmc:~$
as does
xbmc@xbmc:~$ makemkvcon stream disk:0
xbmc@xbmc:~$
I have noticed a file in ~/.MakeMKV/
if I purge it and then run the above it is recreated.
xbmc@xbmc:~$ ls ~/.MakeMKV/
MKB_v35_Skyfall.tgz  update.conf
xbmc@xbmc:~$
xbmc@xbmc:~$ sudo apt-cache policy libaacs0
libaacs0:
  Installed: 0.7.1-1~ppa1
  Candidate: 0.7.1-1~ppa1
  Version table:
 *** 0.7.1-1~ppa1 0
        500 http://ppa.launchpad.net/n-muench/vlc/ubuntu/ trusty/main amd64 Packages
        100 /var/lib/dpkg/status
     0.7.0-1 0
        500 http://gb.archive.ubuntu.com/ubuntu/ trusty/universe amd64 Packages
xbmc@xbmc:~$
xbmc@xbmc:~$ sudo apt-cache policy libbluray1
libbluray1:
  Installed: 1:0.6.2-1~ppa1
  Candidate: 1:0.6.2-1~ppa1
  Version table:
 *** 1:0.6.2-1~ppa1 0
     1:0.5.0-1 0
xbmc@xbmc:~$ sudo apt-cache policy libbluray-bdj
libbluray-bdj:
  Version table:
     1:0.5.0-1 0
xbmc@xbmc:~$ sudo apt-cache policy libbluray-bin
libbluray-bin:
  Installed: (none)
  Version table:
     1:0.6.2-1~ppa1 0
     1:0.5.0-1 0
xbmc@xbmc:~$
xbmc@xbmc:~$ ls ~/.config/aacs/
KEYDB.cfg
xbmc@xbmc:~$ ls ~/.config/bdplus/vm0/
aes_keys.bin            device_discovery_3.bin  ecdsa_keys.txt   mem_area_04.bin  mem_area_07.bin  mem_player_executable.bin
device_discovery_1.bin  device_discovery_4.bin  mem_area_02.bin  mem_area_05.bin  mem_free.bin     mem_player_name.bin
device_discovery_2.bin  device_discovery_5.bin  mem_area_03.bin  mem_area_06.bin  memory.map       mem_player_version.bin
xbmc@xbmc:~$
I am stuck as to what it could be causing it :(
Thanks in advance.
S.
Re: [Help] Cant open disk (SkyFall)
If you launch MakeMKV to rip the disk, does it generate errors? If MakeMKV is having issues with the disk itself, it would affect how it serves it up to other applications.
ndjamena
Post by ndjamena »
The Command is "disc" NOT "disk".
Saner
Post by Saner »
I dont believe the words "fu*&ing idiot" quite cover how i am feeling right about now.
Thanks for pointing out my stupidity and age :mrgreen:
