I just tried makemkv a few days ago and it works pretty fine. The only exception is a relatively new dvd "non-stop".
I hope the given details are sufficient.
disc-information:
Label: _NON_STOP_#D38F
Timestamp: 2014-05-30 16:00:10
Data capacity: 7.92 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
debug information
Optical drive "DVD+R-DL HL-DT-ST DVDRW GS21N SA18d" opened in OS access mode.
Title #1 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 1-1 were removed from title start
Cells 3-3 were removed from title end
Title #5 was added (1 cell(s), 0:02:06)
Title #6 has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 was added (1 cell(s), 0:02:18)
Cells 2-end were skipped due to cell commands (structure protection?)
Title #8 was added (1 cell(s), 0:02:16)
Title #9 was added (1 cell(s), 0:02:15)
Title #10 has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 was added (1 cell(s), 0:02:17)
Title #15 was added (1 cell(s), 0:02:05)
Title #16 has length of 116 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 was added (1 cell(s), 0:03:25)
Title #18 was added (1 cell(s), 0:06:23)
Title #19 was added (1 cell(s), 0:02:10)
Title #20 was added (1 cell(s), 0:09:56)
Title #21 was added (1 cell(s), 0:07:25)
Title #22 was added (1 cell(s), 0:05:01)
Title #23 has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 was added (1 cell(s), 0:11:45)
Title #26 was added (1 cell(s), 0:20:24)
Title #28/36 has length of 57 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #28/38 has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 was added (15 cell(s), 1:42:20)
DEBUG: Code 10551305 at d/a6<?(S9hq/UCh::213142128
DEBUG: Code 0 at d/a6<?(S9hq/UCh::213143301
DEBUG: Code 0 at FXQW[4$r`T|P&q'^[1:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 13-13 were removed from title end
Title #30 was added (11 cell(s), 1:41:43)
Title #31 was added (12 cell(s), 1:10:17)
Title #32 was added (11 cell(s), 1:41:43)
Title #33 was added (11 cell(s), 1:41:43)
Title #35 was added (16 cell(s), 1:43:38)
Title #37 was added (13 cell(s), 1:20:51)
Title #39 was added (16 cell(s), 1:43:38)
Title #40 was added (11 cell(s), 1:41:43)
Title #41 was added (11 cell(s), 1:41:43)
Title #42 was added (11 cell(s), 1:41:43)
Title #44 was added (15 cell(s), 1:43:14)
Title 1 in VTS 27 is equal to title 1 and was skipped
Title 1 in VTS 32 is equal to title 1 and was skipped
DEBUG: Code 233 at zqEEv8RM1xeiqsqpD1uHwwrt:0
When finished, there are several tracks to convert, but non of them work. This is what I get, when trying:
Error 'Scsi error - MEDIUM ERROR:UNRECOVERED READ ERROR' occurred while reading '/VIDEO_TS/VTS_28_1.VOB' at offset '358400'
I hope there´s a way to fix this. I really appreciate this great tool.
best regards
Norman
non-stop movie - error
Re: non-stop movie - error
The drive can't read parts of the disk. By itself, MakeMKV can't do anything about that, except tell the drive to try more times (that's in the preferences, under "I/O").MEDIUM ERROR:UNRECOVERED READ ERROR
First option is to try cleaning the disk, to make sure there are no finger prints and such causing the problem. I do it with furniture polish, which also waxes the disk; this helps with small scratches you might not see, but can affect how the laser sees the little pits on the disk. For some disks, it is necessary to use a different drive - different drives have different focusing abilities and tolerances for out-of-focus disks. A DVD drive can (usually) read a marginal DVD better than a Bluray drive, due to the wavelength of the laser light.
