expendables 3 source file
msweetz
#1 Post by msweetz » Tue Nov 25, 2014 3:30 pm
anyone know which source file to use when backing up expendables 3 bluray? there's over 100 and all of them have the same run time that matches the movie.
WAYFLIX
Re: expendables 3 source file
#2 Post by WAYFLIX » Tue Nov 25, 2014 5:49 pm
Would like to know the same. I made an unencrypted backup with MakeMKV and ran it though BDinfo but i have no idea where to go from there. Any help?
dannyboy48888
#3 Post by dannyboy48888 » Tue Nov 25, 2014 10:38 pm
using my method here: http://www.makemkv.com/forum2/viewtopic ... =45#p33998 and powerDVD 14 I got the one and only correct title out of them all. In my case it was title 172 or 00594.mpls. I highly recommend you double check the output as each batch can have a different "correct" play-list!
WAYFLIX
#4 Post by WAYFLIX » Wed Nov 26, 2014 1:33 am
dannyboy48888 wrote:using my method here: http://www.makemkv.com/forum2/viewtopic ... =45#p33998 and powerDVD 14 I got the one and only correct title out of them all. In my case it was title 172 or 00594.mpls. I highly recommend you double check the output as each batch can have a different "correct" play-list!
What is the playlist order (segment map) for your 00594.mpls?
dannyboy48888
#5 Post by dannyboy48888 » Wed Nov 26, 2014 1:39 am
508,504,520,513,515,514,509,510,507,505,516,517,501,518,502,506,503,519,512,511
WAYFLIX
#6 Post by WAYFLIX » Wed Nov 26, 2014 1:47 am
dannyboy48888 wrote:508,504,520,513,515,514,509,510,507,505,516,517,501,518,502,506,503,519,512,511
Thanks...I show the same...it's labeled title 171 though...first one being 0 in MakeMKV I'm guessing that makes in title 172 then?
dannyboy48888
#7 Post by dannyboy48888 » Wed Nov 26, 2014 1:51 am
That's the kicker. It can be different as I've seen the segments named a number off depending on the batch. You'll notice 30sec here and there out of order if its wrong so verifying in a player is the only way to know for sure
FL-Ronin
#8 Post by FL-Ronin » Wed Nov 26, 2014 2:27 am
SPOT ON.... ripped and watched side by side with blu-ray muted to make sure they matched. Learned something new today. Thanks for Info.
Ronin
dannyboy48888
#9 Post by dannyboy48888 » Wed Nov 26, 2014 2:39 am
Glad it helped!
gamecaptor
#10 Post by gamecaptor » Wed Nov 26, 2014 6:23 am
So then does this look right?
Title information
Source file name: 00594.mpls
Duration: 2:06:27
Chapters count: 16
Segment count: 20
Segment map: 508,504,520,513,515,514,509,510,507,505,516,517,501,518,502,506,503,519,512,511
File name: Expendables_3_t172.mkv
NEO Dan
#11 Post by NEO Dan » Thu Nov 27, 2014 11:32 pm
Interestingly the disc I have came out like this:
Title information
Duration: 2:06:27
Chapters count: 16
Segment count: 20
File name: Expendables_3_t171.mkv
I'll report back after I watch it.
Batiatus
#12 Post by Batiatus » Fri Nov 28, 2014 2:27 am
I can't get E3 to even read the disc. Just keeps giving me errors and a link to send the report due to some new level of encryption. :(
Never mind. The updated 1.9.0 seems to have worked. Thought I had installed it when I first opened up the program today but for some reason it was still the older version.
akula682
#13 Post by akula682 » Fri Nov 28, 2014 3:55 am
If you are having trouble with reading the disk go get it replaced, I had to do that today.
All of you that posted the segment maps... thanks im glad it works for you and for others but NOT ONE of my 20+ GB files starts with 508, and the Source file name: 00594.mpls doesn't show up anywhere either, they all start with 280. Does anyone have that particular style disk?
WAYFLIX
#14 Post by WAYFLIX » Fri Nov 28, 2014 8:05 pm
NEO Dan wrote:Interestingly the disc I have came out like this:
Title information
Duration: 2:06:27
Chapters count: 16
Segment count: 20
Any luck NEO? I have the same info as you.
ASX147
#15 Post by ASX147 » Sat Nov 29, 2014 1:49 am
hi
so like many other I can't back up the EXP3 blu ray on my storage drive.
MKV says it uses a new encryption code.
and I can t even have audio through mu AURORA blu ray player. any one can ?
AURORA cant even read the core DOlbY TRUE HD.
thanks for any input
