After scanning the Catching Fire DVD, it found a number of titles that are the correct length, no surprise. One of them is track 28, which is the one that Apple's DVD player lists as the title when playing the movie.
MakeMKV scans this track and lists it time ("Title #28 was added (25 cell(s), 2:25:55)") but this title doesn't actually appear in the selectable titles, it skips from 26 to 31.
Anyone know either which track to select or why MKV is not listing the track that it said it's adding?
Catching Fire DV Missing Track
Re: Catching Fire DV Missing Track
Do you have debug logging turned on? If so, what is logged during the scan portion?
ac_mkv
Log output below. Doesn't really look like much additional info related to title 28. Results skip from 26 to 31.
Title #25 was added (24 cell(s), 1:51:12)
Title #26 was added (29 cell(s), 2:26:35)
DEBUG: Code 10551308 at d/a6<?(S9hq/UCh::213142128
DEBUG: Code 0 at d/a6<?(S9hq/UCh::213143301
DEBUG: Code 0 at FXQW[4$r`T|P&q'^[1:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Title #31 was added (30 cell(s), 2:33:59)
Title 1 in VTS 16 is equal to title 1 and was skipped
Title 1 in VTS 30 is equal to title 1 and was skipped
DEBUG: Code 233 at MA9vtIVMd3WmVsKXFvwBB7VD:0
linuxuser
Guys, is there a chance that this will be fixed soon?
I suffer from the same bug, that occurs on Walking Dead Season 4 Blueray set that I just purchased.
AnyDVD & Handbrake do just fine, but first, I don't want Windows involved and second, I dont want to convert, just to rip and store the files on my NAS for streaming.
As the bug occurs on Windows as well as on Linux (Ubuntu 14.04), even when I start MakeMKV over AnyDVD. So this is obviously not protection issue, just a to tight fake file checker?
MakeMKV v1.9.0 linux(x64-release) gestartet
Direkter Zugriffsmodus wird verwendet
Evaluierungsversion. Es verbleiben noch 29 von 30 Tagen.
Datei 00006.mpls wurde als Titel 0 hinzugefügt
Datei 00007.mpls wurde als Titel 1 hinzugefügt
Datei 00008.mpls wurde als Titel 2 hinzugefügt
Datei 00036.mpls wurde als Titel 3 hinzugefügt
Datei 00005.mpls wurde als Titel 4 hinzugefügt
Titel #00011.mpls hat eine Länge von 109 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel #00020.m2ts hat eine Länge von 5 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel #00014.m2ts hat eine Länge von 10 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel #00025.m2ts hat eine Länge von 0 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel #00026.m2ts hat eine Länge von 17 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel #00027.m2ts hat eine Länge von 30 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel #00028.m2ts hat eine Länge von 8 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel #00029.m2ts hat eine Länge von 33 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel #00022.m2ts hat eine Länge von 30 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel #00023.m2ts hat eine Länge von 25 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel #00024.m2ts hat eine Länge von 2 Sekunden und wurde übersprungen, da die minimale Titellänge 300 Sekunden beträgt
Titel 00036.mpls ist mit Titel 00005.mpls identisch und wurde übersprungen
Die Aufgabe wurde erfolgreich abgeschlossen
BTW: I will happily pay for a license once this bug is fixed as I welcome your efforts to code also for Linux. But 60 Euros is a little bit tough. A Sony BlueRay player on Amazon costs 44 Euros. I think 30 euros incl. vat would be more acceptable for the general audience.
http://www.makemkv.com/manualdvd/
This allows you to bypass the fake title checking on 1.9.0 and later.
