Let's Be Cops with 'no FUTs where obtained' with ver. 1.9.0
skoalbandit70
#1 Post by skoalbandit70 » Fri Nov 21, 2014 5:47 am
Movie: Let's Be Cops.
The exact message is: "BD+ code processed but no FUTs were obtained, errors may follow'.
Using version 1.9.0 on Mac OS X. The video has garble in it. If you look at the post ' Post subject: Video errors converting Dawn of the Planet of the Apes', this is pretty much what is happening to this Bluray output. I did drop down a a few versions incrementally. So I tried it with versions of MakeMKV back to 1.8.10 (that's the earliest I had), since I read a post by someone who suggested trying that. Same error with each version.
I would be more than happy to dump out whatever is needed and send it to someone. I bought a registered version of MakeMKV and very much enjoy the product!
Re: Let's Be Cops with 'no FUTs where obtained' with ver. 1.
#2 Post by Woodstock » Fri Nov 21, 2014 5:16 pm
The message you received should have contained a path to a file that was created with the BD+ information. That would get sent to svq@makemkv.com for analysis.
When Mike gets to it, the next time you run MakeMKV it should pick up the revised SVQ file to rip the disk. You would just have to periodically insert it for ripping, and, when the FUT messages disappear, you're ready to rip.
BigDog66
#3 Post by BigDog66 » Sat Nov 22, 2014 1:14 am
I just emailed dump files from 2 different versions so hopefully Mike will be able to do something with them
#4 Post by mike admin » Sat Nov 29, 2014 9:26 pm
We are still missing one dump for this disc. If it still doesn't work, try opening the disc and send the produced dump file.
ggking7
#5 Post by ggking7 » Sat Dec 20, 2014 5:19 pm
Same problem here.
eamondunphy
#6 Post by eamondunphy » Tue Dec 23, 2014 9:21 pm
same for me to
tomn@aservintinc.com
#7 Post by tomn@aservintinc.com » Thu Jan 08, 2015 8:37 pm
I'm having the same problem with "Dawn of the Planet of the Apes" BD on version 1.9.0 - is there a fix for this yet?
#8 Post by Woodstock » Fri Jan 09, 2015 12:47 am
Assuming that everyone that saw the message about no FUTs clicked on the links that were generated so that Mike got the additional information he needed, the USUAL case is that, within a day of him getting a chance to work on it, MakeMKV will automatically start working for that disk, IF you have allowed automatic updates.
#9 Post by tomn@aservintinc.com » Fri Jan 09, 2015 3:52 pm
Thanks, I didn't realize that there was an option for auto update. I turned it on and now it works fine.
jonesthegas
#10 Post by jonesthegas » Wed Jan 21, 2015 4:20 pm
I have a similar issue with another title (Belle). The dump file is 3MB and over the 2MB limit for a PM. How can I get the file to Mike for this title?
Martin
Westyfield2
#12 Post by Westyfield2 » Fri Jan 23, 2015 11:48 am
jonesthegas wrote:I have a similar issue with another title (Belle).
Same. "BD+ code processed but no FUTs were obtained, errors may follow."
Debug log started at Fri Jan 23 11:41:14 2015 , written by MakeMKV v1.9.1 win(x64-release)
001005:0000 MakeMKV v1.9.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Westyfield2/MakeMKV_log.txt
DAFD=PAAAADAAAAEABDQkEGAACAQ==
DCE=60pFAkLqhcNTutzNO074fgdZoZAA9MLl7u+RqYuROe0wjhlFUzz08bkaWq9qwH9t8kqV61OEihlMZl4fEASnV2rT8vq0cWu6FBdzqzCxS4312pvSFywaWWHokqePdG5H2ZpIivhWjctqF47SMVgHjwAH91edOxaivw==
003317:0000 Loaded 363 SVQ file(s)
003326:0000 Processing BD+ code, please be patient - this may take up to few minutes
003324:0000 Processing BD+ code using generic SVQ from builtin/00000.svq
SVQ: generic005 builtin/00000.svq
003332:0000 Saved BD+ dump file as C:\Users\Westyfield2/.MakeMKV/dump_Belle_79700C33CFB5BAD8_D.tgz
003327:0404 BD+ code processed but no FUTs were obtained, errors may follow
DISCID=79700C33CFB5BAD86943E457165A8E0A58A99B74
003307:0000 File 00350.mpls was added as title #0
003025:0000 Title #00001.mpls has length of 71 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00800.mpls is equal to title 00350.mpls and was skipped
003309:0000 Title 00850.mpls is equal to title 00350.mpls and was skipped
003025:0000 Title #00002.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00061.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00073.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00400.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00450.m2ts was added as title #1
003307:0000 File 00451.m2ts was added as title #2
003307:0000 File 00452.m2ts was added as title #3
003307:0000 File 00453.m2ts was added as title #4
003307:0000 File 00454.m2ts was added as title #5
003307:0000 File 00455.m2ts was added as title #6
003307:0000 File 00461.m2ts was added as title #7
003307:0000 File 00456.m2ts was added as title #8
003025:0000 Title #00507.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Application exited at Fri Jan 23 11:43:15 2015
Have emailed the dump file :).
