New movie "Le Chef" looks to have AACS v50
johng
Post by johng »
Makemkv hangs trying to backup the movie. Are there plans to update Makemkv to v50?
johng
Re: New movie "Le Chef" looks to have AACS v50
Yes, version 1.8.15 adds support for AACSv50, and it's coming "real soon now" to also fix a problem with BD+ in 1.8.14.
But, if you had AACSv50, MakeMKV would note that in the log. Are you sure it isn't another issue? Debug logs would help....
johng
Post by johng »
I'm just getting that info from under the Source section on Makemkv after the disc loads where is says "Protection: AACS v50" (towards the top left side of the screen). If I try to do a backup of the disc Makemkv hangs, and I need to go into the windows task manager to shut if down as it becomes unresponsive.
johng
johng
Post by johng »
For what it's worth this is the debug file. As I said MakeMKV hangs rather quickly and I need to use the task manager to kill it.
johng
Debug log started at Fri Nov 14 14:32:38 2014 , written by MakeMKV v1.8.13 win(x86-release)
Using 523392KB for read cache.
001005:0000 MakeMKV v1.8.13 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\jgiguere/MakeMKV_log.txt
005075:0000 The new version 1.8.14 is available for download at /download/
005072:0000 Backing up disc into folder "E:/Le Chef"
csf8=1
csf6
johng
Post by johng »
I'll be sending the movie back to Netflix in the AM (11/15/14), so if you need me to do anything else to help debug this let me know ASAP.
johng
