Makemkv hangs trying to backup the movie. Are there plans to update Makemkv to v50?
johng
New movie "Le Chef" looks to have AACS v50
Re: New movie "Le Chef" looks to have AACS v50
Yes, version 1.8.15 adds support for AACSv50, and it's coming "real soon now" to also fix a problem with BD+ in 1.8.14.
But, if you had AACSv50, MakeMKV would note that in the log. Are you sure it isn't another issue? Debug logs would help....
johng
I'm just getting that info from under the Source section on Makemkv after the disc loads where is says "Protection: AACS v50" (towards the top left side of the screen). If I try to do a backup of the disc Makemkv hangs, and I need to go into the windows task manager to shut if down as it becomes unresponsive.
johng
johng
johng
For what it's worth this is the debug file. As I said MakeMKV hangs rather quickly and I need to use the task manager to kill it.
johng
Debug log started at Fri Nov 14 14:32:38 2014 , written by MakeMKV v1.8.13 win(x86-release)
Using 523392KB for read cache.
001005:0000 MakeMKV v1.8.13 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Documents and Settings\jgiguere/MakeMKV_log.txt
005075:0000 The new version 1.8.14 is available for download at /download/
005072:0000 Backing up disc into folder "E:/Le Chef"
csf8=1
csf6
johng
csf8=1
csf6
johng
I'll be sending the movie back to Netflix in the AM (11/15/14), so if you need me to do anything else to help debug this let me know ASAP.
johng
johng
