Is this a problem with the disc?
Marc_G
#1 Post by Marc_G » Tue Mar 09, 2010 12:40 am
With AnyDVDHD NOT RUNNING, I tried to open Fringe S1D3. Got an error partway through while opening. Here's the log:
Debug log started at Tue Mar 09 00:34:40 2010 , written by MakeMKV v1.5.0 beta win(x64-release)
001005:0000 MakeMKV v1.5.0 beta win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\xxxx/MakeMKV_log.txt
001003:0020 DEBUG: Code 2 at 5>,*|U\mV`v;7`LD:213135251
001003:0020 DEBUG: Code 101016576 at '^cK!q]JB$-HsrWc$>:121263429
001003:0020 DEBUG: Code 101016576 at '^cK!q]JB$-HsrWc$>:29393654
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occured while reading '/BDMV/STREAM/00016.m2ts' at offset '2615224320'
DISCID=E5061BA6CE727F09CA5794E60CD27D872B9C2389
001002:0020 LIBMKV_TRACE: No CC5 in 00004
003307:0000 File 00004.mpls was added as title #0
001002:0020 LIBMKV_TRACE: No CC5 in 00010
003309:0000 Title 00010.mpls is equal to title 00004.mpls and was skipped
003025:0000 Title #00006.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00016.m2ts was added as title #1
003025:0000 Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00007.m2ts was added as title #2
003025:0000 Title #00006.m2ts has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 106 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00008.m2ts was added as title #3
003025:0000 Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
I'm ripping it episode-by episode now to see if I can get the content off.
AnyDVDHD does hit a drive reading error at 13%; in combination with the log above I'm assuming I need to find a way to return this disc set for exchange (gift, what a pain it will be).
Marc
Marc_G
Re: Is this a problem with the disc?
#2 Post by Marc_G » Tue Mar 09, 2010 1:17 am
Died partway through the rip. Here's the ripping log. I'm assuming a physical problem but open to other thoughts:
005014:0000 Saving 4 titles into directory C:/Video/Fringe_Season_1_Disc_3
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occured while reading '/BDMV/STREAM/00016.m2ts' at offset '1409740800'
001003:0020 DEBUG: Code 0 at V=L.$ul2cX6oseCQ:121268512
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occured while reading '/BDMV/STREAM/00016.m2ts' at offset '1410594816'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occured while reading '/BDMV/STREAM/00016.m2ts' at offset '1410791424'
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:ILLEGAL MODE FOR THIS TRACK' occured while reading '/BDMV/STREAM/00016.m2ts' at offset '1410920448'
#3 Post by mike admin » Tue Mar 09, 2010 6:37 am
Looks like physically damaged disc indeed.
