Beauty & the Beast Diamond Edition
azisles02
Post by azisles02 »
Finally got Plex, so I've been reconverting my blu-rays to 5.1 audio mvk files to convert to 5.1 audio 1080p mp4s. Most discs are working just fine, but having issues with the Beauty & the Beast Diamond Edition blu-ray. I'm using Makemvk v1.8.14, a Pioneer BRC-207D blu-ray drive. I tried the blu-ray disc in my Xbox one & works just fine. I included a text version of the log below:
File 00270.mpls was added as title #0
File 00271.mpls was added as title #1
File 00277.mpls was added as title #2
File 00278.mpls was added as title #3
File 00253.mpls was added as title #4
File 00020.mpls was added as title #5
File 00800.mpls was added as title #6
File 00801.mpls was added as title #7
Title 00802.mpls is equal to title 00800.mpls and was skipped
Title 00803.mpls is equal to title 00801.mpls and was skipped
File 00021.mpls was added as title #8
File 00022.mpls was added as title #9
File 00023.mpls was added as title #10
File 00024.mpls was added as title #11
File 00025.mpls was added as title #12
File 00267.mpls was added as title #13
File 00269.mpls was added as title #14
Title 00272.mpls is equal to title 00277.mpls and was skipped
Title 00274.mpls is equal to title 00278.mpls and was skipped
Title 00273.mpls is equal to title 00277.mpls and was skipped
Title 00275.mpls is equal to title 00278.mpls and was skipped
Title #00287.mpls has length of 131 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00000.m2ts has length of 0 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00075.m2ts has length of 0 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00076.m2ts has length of 0 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00250.m2ts has length of 64 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00259.m2ts has length of 20 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00012.m2ts has length of 24 seconds which is less than minimum title length of 200 seconds and was therefore skipped
File 00026.m2ts was added as title #15
File 00027.m2ts was added as title #16
Title #00252.m2ts has length of 7 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00028.m2ts has length of 24 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00029.m2ts has length of 24 seconds which is less than minimum title length of 200 seconds and was therefore skipped
File 00030.m2ts was added as title #17
File 00034.m2ts was added as title #18
Title #00035.m2ts has length of 5 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00031.m2ts has length of 47 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00032.m2ts has length of 47 seconds which is less than minimum title length of 200 seconds and was therefore skipped
File 00033.m2ts was added as title #19
File 00037.m2ts was added as title #20
Title #00810.m2ts has length of 58 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00817.m2ts has length of 58 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00813.m2ts has length of 195 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00814.m2ts has length of 137 seconds which is less than minimum title length of 200 seconds and was therefore skipped
File 00815.m2ts was added as title #21
File 00816.m2ts was added as title #22
File 00811.m2ts was added as title #23
Title #00812.m2ts has length of 76 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00251.m2ts has length of 48 seconds which is less than minimum title length of 200 seconds and was therefore skipped
File 00818.m2ts was added as title #24
Title #00819.m2ts has length of 137 seconds which is less than minimum title length of 200 seconds and was therefore skipped
File 00820.m2ts was added as title #25
Title #00254.m2ts has length of 105 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00255.m2ts has length of 64 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00256.m2ts has length of 7 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00257.m2ts has length of 75 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00258.m2ts has length of 107 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00260.m2ts has length of 52 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00261.m2ts has length of 83 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00262.m2ts has length of 77 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00263.m2ts has length of 49 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00264.m2ts has length of 76 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00265.m2ts has length of 77 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00266.m2ts has length of 32 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00060.m2ts has length of 7 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00268.m2ts has length of 6 seconds which is less than minimum title length of 200 seconds and was therefore skipped
File 00276.m2ts was added as title #26
Title #00279.m2ts has length of 7 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00280.m2ts has length of 118 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00281.m2ts has length of 7 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00282.m2ts has length of 68 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00283.m2ts has length of 101 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00285.m2ts has length of 82 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00286.m2ts has length of 48 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00288.m2ts has length of 7 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00289.m2ts has length of 4 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00290.m2ts has length of 4 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00291.m2ts has length of 4 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00292.m2ts has length of 4 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00293.m2ts has length of 4 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00294.m2ts has length of 4 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00295.m2ts has length of 4 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Title #00036.m2ts has length of 3 seconds which is less than minimum title length of 200 seconds and was therefore skipped
Saving 1 titles into directory C:/Video/mvk
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00813.m2ts' at offset '464123904'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00813.m2ts' at offset '464449536'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00813.m2ts' at offset '464455680'
DEBUG: Code 0 at zLFm}Cl+Jq>J@h'nR"hl:121263038
DEBUG: Code 0 at Dh_g0qtWCy&KnL~o%#)8:121261888
DEBUG: Code 0 at zLFm}Cl+Jq>J@h'nR"hl:213130559
DEBUG: Code 226785 at zLFm}Cl+Jq>J@h'nR"hl:29393286
DEBUG: Code 0 at ca,H%G?W>w/ 94x+UoU.c:213135090
DEBUG: Code 0 at D_0~HE]]/7x\k#xs[Wq:29396621
DEBUG: Code 0 at O;j4[m:P#D$+3NqRg:213131893
DEBUG: Code 0 at O;j4[m:P#D$+3NqRg:121263406
DEBUG: Code 0 at O;j4[m:P#D$+3NqRg:29393907
Failed to save title 6 to file C:/Video/mvk/Beauty_and_the_Beast_(Disc_1)_t06.mkv
0 titles saved, 1 failed
Re: Beauty & the Beast Diamond Edition
Unfortunately, MakeMKV can't work around the drive not being able to read the disk. I'd start by cleaning the disk. Sometimes, you can work around these unreadable sections by trying a different drive, or increasing the number of retries (IO section of the MakeMKV settings).
