Using anything other than default profile it won't create MK
ndjamena
Re: Using anything other than default profile it won't creat
#16 Post by ndjamena » Thu Nov 06, 2014 7:03 am
Are you using the GUI? Have you unchecked the DTS track and/or altered the default selection rule?
If it's the CLI I'm not sure what default selection rule it follows.
jmztaylor
#17 Post by jmztaylor » Thu Nov 06, 2014 12:48 pm
ndjamena wrote:Are you using the GUI? Have you unchecked the DTS track and/or altered the default selection rule?
I loaded the GUI once to create and setup .MakeMKV/settings.conf
Other than that I have been in CLI
ndjamena
#18 Post by ndjamena » Thu Nov 06, 2014 1:09 pm
Try the GUI, if that works then it's user error.
