Using anything other than default profile it won't create MK
ndjamena
Re: Using anything other than default profile it won't creat
Post by ndjamena »
Are you using the GUI? Have you unchecked the DTS track and/or altered the default selection rule?
If it's the CLI I'm not sure what default selection rule it follows.
jmztaylor
Post by jmztaylor »
ndjamena wrote:Are you using the GUI? Have you unchecked the DTS track and/or altered the default selection rule?
I loaded the GUI once to create and setup .MakeMKV/settings.conf
Other than that I have been in CLI
ndjamena
Post by ndjamena »
Try the GUI, if that works then it's user error.
