Green Lantern Doesn not copy
whymyname
#1 Post by whymyname » Mon Nov 03, 2014 2:35 am
MakeMKV v1.8.10 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\gl906469/MakeMKV_log.txt
The new version 1.8.14 is available for download at http://www.makemkv.com/download/
File 00100.mpls was added as title #0
Title #00054.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00011.m2ts was added as title #1
File 00010.m2ts was added as title #2
Saving 1 titles into directory D:/Video/Green_Lantern
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '1631649792'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, OPERATION IN PROGRESS' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '1631778816'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '1631975424'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '1632172032'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, OPERATION IN PROGRESS' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '1632301056'
Error 'Scsi error - MEDIUM ERROR:NO SEEK COMPLETE' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '1632497664'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '1632497664'
DEBUG: Code 0 at bd\[Kd6uTi,QKe730o}M:121263038
DEBUG: Code 0 at ev.&ElmW&E11:JMeK=3x:121261888
DEBUG: Code 0 at bd\[Kd6uTi,QKe730o}M:213130559
DEBUG: Code 797118 at bd\[Kd6uTi,QKe730o}M:29393286
DEBUG: Code 0 at 4(yOYXRk(~=y3s-rF"jD,:213135090
Failed to save title 0 to file D:/Video/Green_Lantern/Green_Lantern_t00.mkv
0 titles saved, 1 failed
Re: Green Lantern Doesn not copy
#2 Post by Woodstock » Mon Nov 03, 2014 11:03 pm
MakeMKV can't deal with hard fails like this - your drive can't read the disk itself.
First steps are to try cleaning the disk. If EVERY disk is now having problems with seeks, though, the drive could be having a problem.
While it doesn't affect your problem here, you should look at updating your copy to at least 1.8.13.
